Slow return valve stuck
   / Slow return valve stuck #1
Petwa
While operating my bush hog I noticed that speed of travel down was kinda slow so I adjusted my return valve to a faster setting which wasn't much of an adjustment, maybe a couple of degrees. It would only move slightly. Now the rate of decent borders on damaging the bush hog if I'm not careful. So I figured I would reset it back to it's original position. It won't move, it's like it's frozen. Is there a way to relieve the pressure so that this valve will operate correctly, I just don't have the guts to use a persuader on it. Any help here is greatly appreciated.
   / Slow return valve stuck #2
I would start with penetrating oil where the lever enters the housing, in case it is just frozen up at that point.
   / Slow return valve stuck #3
Penetrating oil is always a good start, after that, try it--if it doesn't start moving easily, there is some mechanical block. It may be just corrosion, or an o-ring that has decayed and is torn up and in the way. Finally there could be a metal piece from higher upstream that broke and went down stream and is now caught. Something that should move easily has a problem and shouldn't be forced---if you force it, it might work, then again you might be buying a valve and have an unusable tractor till it comes in.
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
2018 John Deere 460E Articulated Dump Truck (A53472)
2018 John Deere...
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2012 Acura TL Sedan (A51694)
2012 Acura TL...
