Slow leaking tire with rim guard.
   / Slow leaking tire with rim guard. #1
massey collector
Bronze Member
Michigan
1938 Massey Harris 101 Or which one
Appers I have a slow leak in a rear R1 tire on my 2017 L3301 Kubota tractor with Rim Guard. Tire showed signs of being low so I added air, then after setting a couple days I saw some thing wet looking in the tire that was on the sticky side, I assume is leaking rim guard.
Do these tractors have intertubes? If so I need to find some place that can remove the rim guard and fix the leak.
IF it is tubeless I may be able to plug the tire or have it plugged.
:D Al
   / Slow leaking tire with rim guard. #2
Should be able to tell by valve stem if they tubeless or tube type. Most new tires are tubeless
   / Slow leaking tire with rim guard. #3
Should be tubeless. Plugging them are easy. After identifying where the leak is, rotate the tire so the leak is on top.
Thanks for the information. I can't tell by the valve stems other than they are not like on my Masseys many of which had cloride in that once.
I think I must have ran over a thorn.
:D Al
   / Slow leaking tire with rim guard. #5
New Land Hero Mini Excavator (A53002)
New Land Hero Mini...
John Deere 6120E (A50323)
John Deere 6120E...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2015 INTERNATIONAL 28 PASSENGER HANDICAP ACCESSIBLE SHUTTLE BUS (A52577)
2015 INTERNATIONAL...
NEW Wolverine 72'' Skid Steer Tiller (A53002)
NEW Wolverine 72''...
1985 Ford Ltl9000 Tender Truck (A52748)
1985 Ford Ltl9000...
