Slow hydraulics for tractor movement
   / Slow hydraulics for tractor movement #1
Mikey450
Humeston, IA
I have a 5210 JD and seem to have an issue with the tractor not moving unless there is a hight enough RPM. The loader and lifts all seem to be fine. Especially when it's hot I have to open the throttle to get the transmission to engage or move.
   / Slow hydraulics for tractor movement #2
Is it a hydrostatic trans.? I‘d check the filters/ suction screen fluid level, if so equipped. May take a look at parking brake, I’ve forgotten to release it in the past.
Mike
   / Slow hydraulics for tractor movement #3
You don't say what transmission you have if it's a regular gear transmission or the power shuttle.
Regular gear drive your clutch is likely toast.
Power shuttle it could be controls or clutch pak.
It's the power shuttle. I'll start with filters and screen.
2012 Volkswagen Jetta Sedan (A50324)
2012 Volkswagen...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
2012 Ford E-150 Passenger Van (A51692)
2012 Ford E-150...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
