Sloppy 425 steering (1995)
   / Sloppy 425 steering (1995) #1
Brianb4465
Canyon,mn
Jd425 & jd445
Steering takes a hall turn of steering wheel before tires turn. Replaced the tie rod ends and clhecked fluid level. There's a triangle plate the rods connect to. There's also the hydraulic steering g pump. Which is likely problem ? Tractor has 2600
Hrs.
   / Sloppy 425 steering (1995) #2
I think the steering cylinders would act up on those also
2017 CENTAURO TANDEM AXLE DRY BULK TRAILER (A54607)
2017 CENTAURO...
2016 CATERPILLAR 730C2 OFF ROAD DUMP (A51246)
2016 CATERPILLAR...
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
2010 MULTIQUIP 25KW GENERATOR (A53843)
2010 MULTIQUIP...
2018 FREIGHTLINER M2 106 26' REEFER BOX TRUCK (A54607)
2018 FREIGHTLINER...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
