Sloppy 3PH Control Lever - Do I need to Rebuild the Hydraulic Assmbly?
   / Sloppy 3PH Control Lever - Do I need to Rebuild the Hydraulic Assmbly? #1
gorgerider
Eastern Washington
Mitsubishi D1550FD
I'm getting to know my Mitsubishi D1550FD (Satoh S470D). One of the things I immediately noticed was the sloppiness of the three-point arm lift control lever. There is also no discernible detent for the neutral position. I've read the operator's manual and service manual and they don't mention any means of adjusting the control lever tension. The only adjustment I see is for the "return to neutral" rod (which also doesn't function). The diagrams show the control lever attached directly to what appears to be an internal valve shaft. The only tension I can see in that sort of setup is replacement of O-rings along that internal shaft, and those would wear rather quickly.
What am I missing? This is a definite safety issue in that if I don't hold my mouth just right, the implements drop or rise quickly.
Thanks for your response.
2011 CIRCLE M 32 FOOT GOOSENECK (A53843)
2011 CIRCLE M 32...
2002 Wacker RD11A Tandem Smooth Drum Roller (A54811)
2002 Wacker RD11A...
2018 KUBOTA SVL95-2S SKID STEER (A52705)
2018 KUBOTA...
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2023 HarbinGer V3...
Crosley 10ft Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
