Slopes with the BR2020 or BR2120
   / Slopes with the BR2020 or BR2120 #1
putt_putt_green
Western Central lower penisula MI
JD 3520
I am looking to replace my zero turn with something that can handle slopes better. My yard is sandy, dry, and not very thick. My yard has 150 foot long 26% slopes, and other slopes not quite as severe. It is relatively flat at top and bottom (< 5%). The zero turn busts loose quite often and I go racing down the hill, tearing up the lawn. I already have a compact utility tractor. My 4 choices seemed to be a Simplicity Prestige, Husqvarna R322T, JD x7xx, and the Kubota GR2x20. On paper the Kubota looks best for my needs.
Will the GR2x20 struggle mowing up my slopes?
- Diesel or gas? Seems like diesel would be better power for climbing slopes. Prefer a 54" mulching deck.
- Turf or bar tires?
   / Slopes with the BR2020 or BR2120 #3
I don't have experience with a GR2020, But I suspect it would break loose going downhill just as easy, although you would have steering during the ride.
I have a similar slope that I have mowed with my zero turns going straight up, then backing down. I have also cut straight up, driven around and go straight up again.
I now cut this bank with a walk behind mower side to side. It's faster, safer, and less stressful.
Rj,
Do you use a regular 20" walk behind, or one of those big fancy ones? My hill is about 1/3 acre, and there is another one I don't mow, which I would like to mow which is probably 1/8 acre. I'll try our push mower once and see how it goes. A little exercise never hurts.
   / Slopes with the BR2020 or BR2120 #5
Rj,
The bank I mow is 120' long x 40' and right at 28 degrees. I mow it with a commercial walk behind, 36" Bobcat Hydro. Best money I ever spent. In the first year living here I started with a manual 20" mower, quickly bought a self propelled 20" mower, then shortly thereafter ended up with the commercial 36".
Homemade Head Cart (A50514)
Homemade Head Cart...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2012 GMC SAVANA BOX TRUCK (A51243)
2012 GMC SAVANA...
2011 Jeep Grand Cherokee Laredo 4WD SUV (A50324)
2011 Jeep Grand...
2014 Dodge Avenger Passenger Car, VIN # 1C3CDZAB4EN223470 (A50324)
2014 Dodge Avenger...
2014 CATERPILLAR 259D SKID STEER (A51242)
2014 CATERPILLAR...
