Henro
Elite Member
- Joined
- Jul 4, 2003
- Messages
- 4,969
- Location
- Few miles north of Pgh, PA
- Tractor
- Kubota B2910, BX2200, KX41-2V mini EX
Curious and nothing more...
But I came to believe after reading some posts here at TBN that acreage calculations are based on flat area, for lack of a better term, and that if one owns land on a slope, that he will have more surface area than another who owns perfectly flat land.
Is this the case?
I believe my property is defined by degrees, minutes and seconds at each corner. It is a rectangle. It is slightly sloped.
I assumed that if the corners were projected upwards to a point in space that was a two dementional plane, and level, that the area calculation would be correct at that point, rather than being based on linerar measurements along the line of the slope.
Otherwise, around here, when people move mountains to make the land flat, for the sake of building a shopping center for example, they would also be decreasing the amount of the property they owned when they changed the lay of the land from sloping to flat.
What am I missing in the equation? Besides the fact that I don't even know how to ask the question properly? /forums/images/graemlins/blush.gif
Is this the case?
