Slooow Hydraulics
   / Slooow Hydraulics #1
njrqs
Veteran Member
Queensland, Australia
Kubota L1-20 DT
After trying to lift out lots of star pickets with the drawbar on my L175, and 1 real stubborn one, my hydraulics won't lift my slasher up to its full height anymore.
I assumed there to be a bypass valve so that if you tried to lift something too heavy, it wouldn't stuff up the hydraulics. This didn't seem to happen and now I have a problem. I swear it now makes more noise than it used to in the hydraulics too.
Any ideas??????
   / Slooow Hydraulics #2
njirqs,
Did you notice a burning smell,also when first useing the lift {setting cold for a while}it makes no differents in the operation.
There are number of things to look for.
Fluid level,filter,weak pump,maybe a vent plug.
I would try changing the fluid and filter first could be water mix in there.
I'm interested in your out come.
Thomas..NH /w3tcompact/icons/wink.gif
   / Slooow Hydraulics #3
<font color=blue>my hydraulics won't lift my slasher up to its full height anymore.</font color=blue>
Is the problem that it won't lift to full height, or that it lifts too slowly, or both?
Bird
   / Slooow Hydraulics
Thomas,
It smells OK but In wondered if I had overheated the oil, therefore should change it. I suspect something more sinister than that !!
   / Slooow Hydraulics
Bird
I won't lift to full height anymore. Speed of lift seems OK but only goes up to about halfway. I think without the weight of the slasher it lifts full height. So I suspect something is slipping in there due to the stress I put it under.
Is there a bypass valve like I thought, or does something bust when a too heavy load is lifted ?
   / Slooow Hydraulics #6
hjrqs, I'll have to admit I really don't know. I'm assuming you checked the oil and it is not low. If it looks clean and smells normal (not burned), it should be all right. There is, of course, a pressure relief valve, and if you pull the lever all the way back and the 3-point does not lift beyond a certain point because the relief valve is opening, you should be able to hear it. And I also assume that your tractor has an adjustment as mine does to adjust the height at which it stops, but I would think if that were out of adjustment it would stop there whether you had a load on it or not. I guess about all I can do is wish you luck and hope it isn't anything serious.
Bird
   / Slooow Hydraulics #7
njrqs,
Sounds like you have a seal etc which needs replacing,which may cause the loud noise plus unable to lift do to the lack of fluid...hope I'm wrong!!
I don't believe you done much damage do to the set relief pressure.
Have you try looking at your hitch as you raise upwards to see if anything catching or bent.
   / Slooow Hydraulics
Thomas & Bird
Thanks again. When I get motivated, maybe tomorrow, I'll try and check all the symptoms. Take the slasher off etc. and see what happens. Will also look at the oil too.
Hope it just goes away but somehow don't think so.
Will post again re this soon !
Cheers
   / Slooow Hydraulics #9
I'd concur with Bird. I think there are basically 3 possible problems.
1) Some mechanical obstruction is inhibiting the lift. This seems unlikely unless you bent or otherwise damaged something with your work. Visual inspection and observing the lift without attachments should let you sort out if this is the problem.
2) Control malfunction. One of the control rods for the list could have been be bent while doing your work. If the lift works OK without a load, then it's not the controls.
3) Internal hydraulic problem. Too me, this sounds most likely. I could easily see how a blown seal would slow lifting and make it difficult for the lift to go full height under load (because fluid is bypassing the seal rather than developing full pressure against the cyl). If it lifts without load, but struggles under load, then I think this is what you are up against.
Good luck and let us know what happens.
Peter
   / Slooow Hydraulics
To all....
Yes without a load the lift goes full height, but even with a light load it only goes about 1/3 the way up. Can't hear any expensive type noises.
Any ideas on how to fix the seal. Sounds expensive !
Cheers
2021 Doosan DX350LC-5 Hydraulic Excavator (A50322)
2021 Doosan...
2016 Big Tex 14ft. T/A Hydraulic Dump Trailer (A50322)
2016 Big Tex 14ft...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
2019 Caterpillar DP35N Forklift (A51691)
2019 Caterpillar...
2015 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A50323)
2015 Chevrolet...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
