slip clutch ?
   / slip clutch ? #1
vaskeet
camden Nc
Kubota l2250
How do you take care of your impliments with slip clutches my tiller manuel says to loosen bolts until clutch slips then retighten to ensure that clutch is not rusted solid prior to use. does anyone use an lube or oil on the clutch?
Randy
   / slip clutch ? #2
How do you take care of your implements with slip clutches my tiller manual says to loosen bolts until clutch the slips then retighten to ensure that clutch is not rusted solid prior to use. Does anyone use an lube or oil on the clutch?
Randy
Randy N0, NO, NO, NO, NO, NO!!!!!!
If you oil it will not work at all for you, and you will be stuck replacing the clutch plates.
All you need is a bit of rubbing alcohol to clean it after you lossen it and then tighten it back up, as it will wash the dust away and then dry off.
leon
FRONTIER SA21G LOT IDENTIFIER 132 (A53084)
FRONTIER SA21G LOT...
2003 GROVE TMS500E MOBILE TRUCK CRANE (A51406)
2003 GROVE TMS500E...
2019 TAKEUCHI TB230 EXCAVATOR (A51246)
2019 TAKEUCHI...
2018 Ford F150 XL (A52384)
2018 Ford F150 XL...
2013 Ford Edge SEL SUV (A51694)
2013 Ford Edge SEL...
