slip clutch vs. overrunning clutch?
   / slip clutch vs. overrunning clutch? #1
Ginormous
Dayton, Ohio
Yanmar YM2210
How does a slip clutch differ from an overrunning clutch? :confused:
   / slip clutch vs. overrunning clutch? #2
A slip clutch functions as overload protection, like a shear pin. If too sharp or extreme of a load is placed onto the PTO drive, the clutch slips, protecting the driveline of the tractor and/or implement from spikes in force that may break something. On a tiller, a large rock, log, or other object may get caught in the tines suddenly, and rather than breaking something on the tiller or tractor, the clutch slips.
An overrun clutch prevents the tractor being propelled forward by power from the implement. Especially with implements that have lots of rotating mass (Mowers, hay rakes, etc) there is a lot of momentum built up in the rotating assembly. Depressing the clutch disconnects the engine from the transmission, but the implement is still fastened directly to the transmission. This means the tractor will be driven forward for quite some distance, with no way for the operator to cut the power to the wheels.
The overrunning clutch is a one way ratchet that keeps the implement from spinning the tractor's PTO shaft and stops the issue of the implement driving the tractor. It's a serious improvement in safety, as well as usefulness of the machine, too. I universally recommend an overrunning clutch for people whose tractors don't have one internally if they are mowing or doing similar things.
   / slip clutch vs. overrunning clutch? #3
what he said. Use overrun clutch on rotary cutter.. Use slip clutch for tiller
   / slip clutch vs. overrunning clutch? #4
Yup been covered pretty well so far! :D
Fwtw obviously a slip clutch is preferable to shear pins in that type applications that require something to "give" you are still in the game.
YANMAR VIO35-6A (A45333)
YANMAR VIO35-6A...
2016 GMC 2500 HD Z71 (A44501)
2016 GMC 2500 HD...
72" Skid Steer Sweeper JCT Standard Flow Sweeper (A42203)
72" Skid Steer...
2005 BIG TEX 18’ T/A UTILITY TRAILER (A45046)
2005 BIG TEX 18’...
2021 John Deere 622F Flex Header  22 Ft  Trailer Included  Excellent Condition (A44789)
2021 John Deere...
2011 CONVEY-ALL  SK-4000 SAND KING TRAILER (A45333)
2011 CONVEY-ALL...
