Slip clutch PTO Shaft???
   / Slip clutch PTO Shaft??? #1
goatman
southern ohio
NH TC 30
I plan to Bush hog with my NH TC30 and 5 ft KK rotary cutter.. I have read a couple of post that refer to "slip clutch PTO shaft"".. Could some enlighten me.. Thanks.. Both tractor and cutter new and I don't want to break any thing....../forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif
   / Slip clutch PTO Shaft??? #2
Rotary mowers, some finish mowers, Post hole diggers, tillers, and just about anything that is PTO powered and engages the ground has some form of drive line protection. It's usually either a shear pin or slip clutch. What these devices do is prevent damage to the tractor drive train by failing if the implement get "stuck" on some immovable object (stump, rock, etc.) A shear pin is a metal rod that is inserted through the PTO coupling and the smooth input shaft of the implement, and is designed to break off and allow the PTO and shaft before the implement to continue spinning. A slip clutch does the same thing but is two interlocking plates that are held togther with springs and "slip" at a predetermined torque to protect the drive train.
Hmmm, I don't really feel that I've described this very good. I'm positive that if you searched the archives oyu would find several discussions about slip clutches.
   / Slip clutch PTO Shaft??? #3
Yes do the search and learn. I like bot a shear pin and a slip clutch. If the slip clutch sticks the pin/bolt still shears protecting my tractor. Remember to service/adjust your slip clutch at the beginning of each mowing season, they stick.
   / Slip clutch PTO Shaft??? #4
With my King Kutter tiller, the PTO drive line's slip clutch has a splined (tongue/grooves that run the length of the sleeve) sleeve connected to the splined shaft of the tiller gear box. In fact all the slip clutches I've seen have a splined output. If the tiller binds, the slip clutch slips and the shaft is free to turn on the tractor side of the clutch. If the clutch fails to slip, having a shear pin wouldn't help as the splines would keep things connected.
With my King Kutter finish mower, the drive line's connection to the mower gear box is a smooth sleeve over a smooth shaft with a cross drilled hole thru both. With a grade 2 bolt (shear pin) holding the two together. It the mower binds, this bolt breaks and the drive shaft is free to turn on the gear box shaft since they are both smooth.
My Ford Rotary mower also uses a shear pin arrangement .
Good luck
   / Slip clutch PTO Shaft??? #5
I think slowrev is talking about an aftermarket addition of a slipclutch.. like.. go to tsc.. buy one with a smooth output end.. use the shearpin to couple it to the gearbox.. then ue the splined male end to hook your driveshaft yoke to.
Best of both worlds.
My howse10' is like yours.. splined shaft that an integral to the pto shaft, slipclutch goes hooks to.
Soundguy
Got the picture.. I am sure I have The shear pin in mine.. But next time I see a Tractor supply will stop and check the Slip clutch Pto.. Thanks for the education.. /forums/images/graemlins/smile.gif
2008 Ford Crown Victoria Sedan (A51694)
2008 Ford Crown...
2015 Chevrolet Silverado 2500HD (A52748)
2015 Chevrolet...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
2004 CATERPILLAR D6R XL CRAWLER DOZER (A51406)
2004 CATERPILLAR...
2016 FORD F550 CREW CAB SERVICE TRUCK (A52576)
2016 FORD F550...
