Rotary Cutter Slip Clutch Maintanence
   / Slip Clutch Maintanence #1
SmallTimeCountry
Kubota 3700SU
Alright, this may or may not be a dumb question but either way, I just need help finding the answer. I have a Land Pride 1872 6 foot roatary mower with a slip clutch. It's time to start mowing and I was going through the maintanence and notcied that I have to make sure that the slip clutch isn't frozen. As you may know, this entails loosing the spring retainer nuts, running the PTO for a couple seconds, and making sure that the clutch slipped properly. I get all that. The problem is removing the protective platic shield from the clutch itself. Is there anyone that has an easy way to do this, so that all eight spring retainer nuts can be accessed? I have not the slightest idea how to get this thing outta the way. Thanks in advance for all the help.
   / Slip Clutch Maintanence #2
I think(IIRC), that if you look at the 'small end' of the large plastic piece..........on either side there will be a slot in the plastic. Using a screwdriver to push in, you should be able to release the tabs that hold the shield in place and pull it back the driveshaft to access the bolts for the slipclutch.
   / Slip Clutch Maintanence #3
and that is a 2 man job one pullin and one running the screw driver, I just went thru that on my 513
   / Slip Clutch Maintanence #4
It's a pain, isn't it?:laughing:
   / Slip Clutch Maintanence #5
it can be a finger pincher
   / Slip Clutch Maintanence #6
To say the least. The screwdriver slipped on me, the tube turned, and I got it in the palm.(I have no idea how I did that)
Be careful SmallTimeCountry
   / Slip Clutch Maintanence #7
Adjusting the slip clutch (I have a 278) is a PITA :mad:. The shield is hard to remove (and using the access openings with the shield on is just as hard) plus the nuts aren't captive or fixed so counting turns for loosening/resetting is made more difficult than necessary. There is no practical method to measure the spring height that I can determine w/o removing the shield (i.e., following the manual instructions for slip clutch adjustment).
This is one area where spending a few dollars more on design for maintenance/repair would be a great convenience to users.
   / Slip Clutch Maintanence #8
Yeah, what a PITA those are. I have one on my tiller. Mower has a shear pin type. I suppose that is why you see a lot of the guards missing. I had to pull mine out and disassemble and clean up the disc. The cross bolt for the clutch to mower shaft was not acessible so I bored a hole in the plastic for access with a socket, solved that problem. Did the adjustment while off the implement usinfg an electronic caliper (HF) . Have done this twice as I have to store outside in this PNW rain, getting ready to do again. They are p[robably OK in the dry SW but they rust up here in 3 months. Seriously contemplating getting a shear pin type instead or just run froze up. Have only stalled the engine once.
Ron
International Farmall 300 Tractor (A50514)
International...
Kivel Pallet Forks (A50121)
Kivel Pallet Forks...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
Richie Water Master 1200 Trough (A50774)
Richie Water...
2007 Kubota M5040D 50HP 4WD Front Loader Utility Tractor (A50322)
2007 Kubota M5040D...
