"slip-clutch" for 3pt snowblower
   / "slip-clutch" for 3pt snowblower #1
deepsnow
Bronze Member
bayview township, bayfield co. WI
NH TC25D
\"slip-clutch\" for 3pt snowblower
Wondering if there exists a mechanical device that would "disengage" the PTO from turning the snowblower drive shaft before the shear point of the shear pin(s) on the shaft. Something that would interface between the PTO & snowblower. The shear pins would be the back-up safety in case this slip device should malfunction.
   / "slip-clutch" for 3pt snowblower #2
Re: \"slip-clutch\" for 3pt snowblower
I'm not sure what you're asking...if the slip-clutch does it's job...the shear bolt would be redundant, unless the slip clutch was not adjusted correctly or was frozen (by rust, perhaps).
However, if the slip-clutch is maintained, it will do it's job.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
2008 JACK COUNTY  130BBL VACUUM TRAILER (A52472)
2008 JACK COUNTY...
John Deere 850 Tractor (NOT RUNNING) (A50774)
John Deere 850...
John Deere Power Unit (A50121)
John Deere Power...
2014 International DuraStar 4300 Terex BT3063 30,000LB Crane Truck (A48081)
2014 International...
(3) Military Transfer Cases (A50121)
(3) Military...
