Slime caused tire slipping on the rim.
   / Slime caused tire slipping on the rim. #1
Redneck in training
Elite Member
South Central Iowa
TYM 330 HST with FEL
We have a lot of thorny trees on our property. Due to constant issues with flat tires on my wife's mower I pumped some slime in them. The problem went away but it created another this spring. When tried to mow first time this year left side of our mower worked right but the right had no power. When the mower was pushed against a tree the left side would spin the tire but the right wouldn't. I bypassed the seat switch so I could lift it and see if the belt is slipping. All looked OK there. I called the dealer and was told that the hydraulic transaxles don't get bad very often but that he saw a broken "ring" in the pump with similar symptoms. Therefore I removed the transaxle, took it apart but found nothing broken. I put it back to the mower and since it exhibited the same symptoms I decided to buy new transaxle. After I installed it right side still had no power. Only then I discovered that the rim was spinning inside the tire. Apparently the slime damaged the rubber of the bead that lost contact with rim shoulder. Surprisingly the tire was not losing any pressure. The slime also completely stripped paint from the rim but didn't cause rusting. Once I determined the cause I painted the rim and replaced both old low pressure with new high pressure tires because they are way thicker. Total cost of misdiagnosis 2300 USD. I have an Eaton transaxle with 1200 hours for sale.
   / Slime caused tire slipping on the rim. #2
Good post of something that can go wrong.
Tires seem to have a disproportional amount of problems... especially the smaller sizes on lighter equipment.
Never used slime or heard of it until I started buying CUT and SCUT and similar... seemed the kids couldn't be 20 minutes with their sand-rail without getting a flat.
Thank you for posting.
Pallet of Car Parts (A47477)
Pallet of Car...
2017 Freightliner MT55 Step Van (A55788)
2017 Freightliner...
1999 JCB 926 (A53314)
2016 Ford F-450 Flatbed Utility Service Truck (A55788)
2016 Ford F-450...
2017 Ford F-150 Pickup Truck (A55788)
2017 Ford F-150...
KUBOTA SSV65 SKID STEER (A52706)
KUBOTA SSV65 SKID...
