Sliding door How too?
   / Sliding door How too? #1
BryanM
Northwest Ohio
John deere 2155, ford 1600
Can someone out their tell me how to hang a header on a pole barn so you have a door opening too the bottomof your truss (or full eve) opening? I am not sure if I back the truss using a 2x12 or what I am suppose to do? And where the hardware hangs? Even pictures would do it. So if you have any input on this do tell? Thanks Bryan
   / Sliding door How too? #2
Need a lot more info! What's the width of your opening? Single or double door? What's your siding? Generally, the rail is mounted on a 2 x XX where XX is a function of span and door weight, attached to a structural wall member at the top of your wall, not the bottom chord of the end truss. On my metal buildings, it only takes one 2x6 attached to the 2x10 batten board to clear the siding. Rail is mounted with GRK screws. Rollers attach to the top 2x6 in the door framing. I have a 12' single and two 6' doubles all mounted this way. Send me a private message if I can help futher.
72'' root grapple (A53421)
72'' root grapple...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A53473)
DeeZee Crossover...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A53473)
Neckover GL24-2-7K...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2015 Volkswagen Jetta Sedan (A53424)
2015 Volkswagen...
