ocaj11
- Joined
- Jun 17, 2004
- Messages
- 190
- Location
- Northeast Texas
- Tractor
- John Deere 5325 4wd, Kubota B7500 HST
I would like to get some opinions on this topic. We are getting ready to build a house on expansive clay soil and I'm trying to figure out which foundation to use. I've read lots of opinions on the Internet, but still can't figure out the most cost effective way to proceed.
I would like to build approximately 2000 sf in a single story, but, I would consider a 1.5 or 2 story if that was less expensive. My plans are to pay someone to do the dry in and I'll do most of the rest as time allows. I'm not in a big hurry once the house is in the dry. I'm located in Southwest Arkansas around Texarkana and I believe the neighbors (1/3 mile) soil test came back with a plasticity around 45 (not 100% on that). A few of the questions I have:
1. We talked to a helical pier installer and he said they usually go around 6 foot deep here to get the required torque. They seem to rely on the torque value to define satisfactory depth. I'm sure the seasonal moisture variation is deeper than 6 feet. What keeps the pier from moving when the soil expands/contracts with more/less moisture? The installer quoted (ballpark) $165/pier at a 6 foot depth. That's $8,250 for 50 helical piers.
2. Drilled concrete piers are an option, but I think you need to go around 15-18 foot deep to keep the expanding/contracting soil from lifting the pier. There is a guy that drills the holes for $100/hr and I have no idea how many 15 foot holes he can drill in an hour.
3. For a concrete slab foundation, I'm not comfortable hauling in a couple of feet of foundation sand and building on top of that. I'm pretty sure we would need to use some sort of pier to support the foundation during the expand/contract cycles. If I'm going to need piers anyway, wouldn't it be cheaper to go pier and beam? We have a 12 yard dump truck and dozer-trackhoe-backhoe to dig out a few feet and backfill with the proper material, but that seems like a lot of work to me and I'm not sure it would be effective.
4. We built a 40 x 60 concrete pad for our metal shop 3 years ago. We weren't too concerned with the slab for the shop, but we did hire the so-called best concrete guy around to do the work. He poured a 4" slab using 12" footings and rebar on 18" (I think) centers. He installed the vapor barrier as well. Eventhough we have a water drainage issue (haven't had a chance to correct this yet) on the back side of the shop, we've only experienced a crack approximately 1/16" wide and 20 foot long. There isn't any seperation to speak of.
5. If we get the slab on proper material and utilize a proper slope to get the water away from the house, is it possible to avoid a busted slab by digging deeper footings, reinforcing the footings with extra rebar and running the interior rebar on 12" centers? 5" slabs significantly better than 4" slabs? Could we pour on 4" of compacted gravel with a drain under the footings to wick any water away?
Basically, there are too many options to choose from and I'm trying to build a proper foundation without killing my budget.
Opinions???
Opinions???
