Skidsteer Quick Attach CAD file?
/ Skidsteer Quick Attach CAD file? #1
MNBobcat
Platinum Member
I have a friend who is going to build me some quick attach plates for my skidsteer. I'm able to find PDFs with the specs, etc. But what I'm looking for is an actual CAD file that could be used by his CNC plasma cutter. I believe it would be a DXF drawing but I'm not sure.
/ Skidsteer Quick Attach CAD file? #2
Its a simply cutout. Nothing too special too it. Take him an attachment and he should be able to build his own program in little to no time.
All of the attachments I build get their own coupler designed for the application. Its cheapest that way. You build the attachment first then build a coupler off of what is there. the coupler is no more than some 3/8 flat stock welded at the right angle in the right places. You don't need a solid plate all the way across. However I always put a pipe or something in the middle of where each half of the plate will be both for strength and to act as a guide for hooking it up.
