Rolando
Platinum Member
- Joined
- Aug 20, 2004
- Messages
- 586
- Location
- Northcentral Florida
- Tractor
- Bobcat Toolcat High Flow Turbo C-series
Still struggling with all the options, but little by little I'm narrowing things down, with a lot of help from the input on this forum. BTW, looking at an L3130 (I think), with the LA723 FEL.
I'm not even sure what the Quick Attach is, or if it does a similar job to the Skid Steer Hitch. I need an easy change because I will need to switch between the regular bucket, a grapple, and a pallet fork for the FEL.
First, what is this Quick Attach feature, and would it give me as much flexibility as the Skid Steer Hitch? As I understand it, the downside of the Skid Steer is that it reduces load capacity because it adds weight and sticks out more from the arms. Is it worth it verses some other way to easily change FEL implements?
Also, I notice from the Implement Chart all sorts of different buckets: square back, heavy duty round, Material bucket. Could you all give me some insight on the differences? Also, does the LA723 come with a bucket, or is that bought separately?
I'm going to need to move a lot of fill because my land is so flat. I want to build up the house about 24" above existing grade and then transition down to get good positive drainage away from the house. Probable don't need that much, but I don't like a house to look flat to the ground.
Boy, I'm just a font of questions! I hope you can bear with me, I am making progress. Little by little the picture is filling in.
