Skid steer or tractor
   / Skid steer or tractor #1
jwrightsman
Medford , wi
GTH 220 Husky
Looking at buying something to plow snow, move dirt for a green house and lift a pallet of pellets (one ton) I have a small rural store and need something to help lift things as I do not have any teen age boys :) There is a case 1845C close by for about 8.5K but it has been insurance salvaged. It has been gone through by a local dealer but has some rust as it was used in a cargo ship. Thoughts? Another dealer wants to sell me a new tractor (Mahindra) 5110 but for a bunch more money and I am not sure I can afford it.
Thoughts on used equipment?
   / Skid steer or tractor #3
In my opinion a skid steer would be the way to go and I am a tractor man. My reasoning is if u are going in and out of a greenhouse you will want something small and maneuverable. Yet will still need large lift capacity. This is skid steer Territory all day long. You won't find many small tractors that can handle 1 ton on pallet forks unless they are special purpose machines. this should not be unreasonable for a decent size skid steer.
   / Skid steer or tractor #4
www.tractorhouse.com = tractors
Construction Equipment For Sale at MachineryTrader.com: Dozers, Scrapers, Wheel Loaders, Excavators, Motor Graders, Caterpillar, Komatsu, Case, John Deere, Volvo = skid steers (sister site of tractorhouse)
www.craglists.org = SearchTempest: Search all of Craigslist nationwide & more (search multi craig list cities at one time)
that turning on a dime, and working in small places = a skid steer. think multi purpose tractor in a zero turn mower form.
fork lifts can also be used. they make attachments for them... pop the forks off, and attach a bucket for example.
telehandler another option.
power-trac = tractor but everything fits on the front.
then ya have a regular tractor.
i would say focus on maneuverability if it is critical, then that going to limit ya from above options.
then 1 ton lifting capacity,
snow plowing may come down to eating the cash for a plow blade or paying for a higher cost snow blower attachment.
the dirt moving could be critical as well. if your setup more like a landscape / greenery place / sand / dirt place. were they have piles ya just run tractor into, and then dump the material into a customers truck bed or like. overall how high you can lift could be critical and how far you need between tractors front end, and side of truck ya dumping into.
--a regular tractor for example. you can let the front wheels drop into mud / slop and still rely on rear wheels to keep ya going so you can reach further back into an area. a skid steer how ever, you may be stuck, not enough reach, not enough ground clearance.
a shuttle shift or HST tractor, or some sort of hydraulic transmission / hydraulic drive/motors most likely what you will want. to allow better overall control.
going used....
make sure you test drive machine
let machine run for 15 minutes or so at high RPM's (well let it warm up first, then let it run at high RPM's and drive it around some). raise bucket, forks or other stuff on unit, and then turn off machine with stuff up. give it 30 minutes or so and see if anything falls down. ((getting an idea of valves or cylinders are going to need a rebuild)).
check brakes (left and right), check emergency brake, check all the lights, go through all the gears (low, med, high, for example) double check reverse, tread on tires (what is left) tires can be a rather expensive items to replace. more so on 4wd / MFWD tractors. and needing to keep correct ratio between front/backs so ya do not tear up the transmission or drive train. check for oil leaks, etc...see how sloppy FEL (front end loader) 3pt hitch, etc.. (hydrualic stuff) on the machine is. some stuff ya just go up to high RPM's, and quick move levers/joystick and everything just shakes, and/or keeps moving a few more feet before it stops. tell them DO NOT CLEAN THE MACHINE! i rather see dust / grease / grim on machine. than a spotless machine. were i can not see oil leaks, grease marks, etc... i know unit is used and expect some issues, so let me see those issues. ask them were you could run the forks or bucket into some place, and test the power of the machine / traction. at how well it digs, and well it fills the bucket up. clean the spot backup and put it back to how ya find it. (gives ya a little more back dragging, and responsiveness of the unit).
bottom line, get a GPS or smart phone with GPS on it. and find a list of units near ya. and go look at 6 plus units maybe a dozen, and just try them out, and get a feel for what you want. about only way ya going to figure out good vs bad, and what is avilable in your area. some stuff is just plain "destroyed" and should be in the junk yard, while others look and seem brand new (how well they were taken care of and how well they were used). it is part of spending a big chunk of cash, and doing your homework / researching.
   / Skid steer or tractor #5
If you decide to go with a skid steer, be sure to drive it around for a while and check the rear visibility. Maneuverability is great with them, but lots of blind spots (in my limited experience) if you're working in tight quarters.
   / Skid steer or tractor #6
You might want to check out the use in a cargo ship - what type of use caused the rust. I saw some used wheel loaders on a dealers lot that were quite rusty for their age. I asked the dealer about their history and they had been used on ships to move fertilizer. They were not as bad as a wheel loader I saw at another dealership, also used on a ship but had been driven over the side and had been underwater in the Persian Gulf for a day. Nasty.
   / Skid steer or tractor #7
Welcome to TBN. Lots of good advice already given, not sure there is much I can add. A skid steer sounds like the tool you need from your description. I would find one that has a significantly higher lift rating than you think you need, that way you won't always be right at the limit and I'm sure once you have it you will be picking up things you hadn't planned on.
   / Skid steer or tractor #8
Keep in mind that ground disturbance is a big problem with skid steers. If you have gravel or other soft surfaces you'll be constantly repairing them. If a skid would serve your needs better than a tractor, take a look at a Bobcat A300. They easily change from all wheel steer to skid steer with the flip of a switch for really tight spots. Llifting a ton of weight is no problem.
   / Skid steer or tractor #9
It is unclear if you are looking to drive inside of the greenhouse, if so, I say get a small articulated loader. More power and easier to run than a skid steer. Outside, a backhoe would be ideal, mint for plowing snow, and older machines are reasonable, since everyone wants an excavator. A full size backhoe will lift a pallet no problem, and to a good height as well.
   / Skid steer or tractor #10
A skidsteer is designed to lift & to some degree dig. A tractor is designed to pull.
A loader on a tractor is a bass ackwards implement. Look at a fork lift.. Heavy axle up front, heavy engine in back, lifting gear close to the vehicle, especially the axle... The exact opposite of a tractor.
Its also called a loader & not a digger for a reason. Its designed for lifting & loading loose material, not digging packed ground.
I ended up with a tractor & loader, but pull implements as much as use the loader.
UNUSED FUTURE FT13CJ EXCAVATOR (A54756)
UNUSED FUTURE...
2005 V.E. ENTERISES 130 BBL STEEL VACUUM TRAILER (A53843)
2005 V.E...
2006 Utility Trailer Trailer, VIN # 1UYVS13256P972701 (A53422)
2006 Utility...
1676 (A54756)
1676 (A54756)
UNUSED LANDHONOR BH-12-72D BACKHOE DIGGER ARM (A54757)
UNUSED LANDHONOR...
10 - 3/16in Plate Steel Sheets (A52377)
10 - 3/16in Plate...
