Buying Advice Skid steer or 1460
/ Skid steer or 1460 #21
/ Skid steer or 1460 #22
/ Skid steer or 1460 #24
I demoed a Bobcat T190 before I bought a PT 1430. I knew if I went with a skid steer I would have to go with tracks because wheeled skid steers have gotten stuck on our property many times. The T190 had a far more capable brush cutter than the PT. The loader was also much stronger. The controls are much more ergonomically laid out than the PT. The T190 also used about twice the fuel, had terribly visibility, was very noisy, did lots of turf damage, and was too tall to fit in most of our buildings.
The PT 1430 does nearly no turf damage, is much smoother, has great traction, and is the best compromise for my needs. A skid steer would be faster for some jobs, but useless for others. The other articulated wheel loaders are far more refined than the equivalent PT. I would like to control the grapple with the same joystick that controls the loader, not have to reach for the loader joy stick, have a hydraulic oil temperature guage, and have tier IV emissions. The other loaders are also substantially more expensive. They have dealer networks, but I would probably need a dealer because the machine is much more complicated.
/ Skid steer or 1460 #25
Yes, well, new property sometimes results in conversions.
30 degree slopes did it for me. I enjoy staying above ground.
YMMV...
All the best,
Peter
/ Skid steer or 1460 #26
It depends on which model of PT you're looking at. Their slope mowers are good for 100% side slope. 100%. That's a 45 degree angle. You will never see any of those machines shown, or any skid steer, operating on anything anywhere near those slopes.
My little PT425, for example, is good for 25 degree angle, so that works out to something between 45-48% side slope, I believe.
I have no idea of what the other PT models are rated for.
MR. where did you get the 25 degree number from? I looked on PT. and nothing....... jim
/ Skid steer or 1460 #27
I found that years ago in some Kohler literature related to my Kohler Command Pro CH25. It said something to the effect to not operate the engine for prolonged periods over 25 degrees or oil starvation will occur.
PT switched to the Robbin engines sometime after that. I don't know what they are rated for.
/ Skid steer or 1460 #28
I guess then a more correct statement is that the engine is rated for 25 degrees but not the PT it's self. on the Ventrac rates the Kubota engines 20-30 degrees intermittent and the Kowasaki on the 4500 P 30 degrees continuous now that being said it is tuff to run sideways on a 30 degree slope and cut grass even with the weight transfer on max. It still wants to crab some and it will tear up the grass a little..... jim
/ Skid steer or 1460 #29
Yep, I've never read an official degree rating for the 25 from PT. I've driven it across a 25 many times. It's very uncomfortable. Up and down short 30+ many times as well. But I won't go across those areas on my property. I can't imaging how uncomfortable a 45 would be.
/ Skid steer or 1460 #30
I had the big air cooled Kohler starve for oil at 25+ degrees on a side slope but this Kowasaki water cooled has never lost oil pressure at 30... and yes 45 is not fun but sometimes I have to for a very short time that wasn't planned .... jim
/ Skid steer or 1460 #31
I've got a couple 45's only about 5' high that I have to go up or down on occasionally. Down's easy. Up I have to get a run at it and pop over the top. I'm fairly certain I'd lose traction after a short bit if it were any longer as it's all sand. I have a road down to my lower field that's about 20 most of the way. That one's no problem. But about 4 hours into a brush cutting day, I notice significant loss of power going up, as the oil is plenty hot by then. So I shut off the brush cutter and head up and start it again at the top. I'm usually ready for a break, a snack, a drink, and let the machine cool down by then. Good time to clear off the front of the machine of debris, check hoses, blade bolts, etc.... then as well.
/ Skid steer or 1460 #32
The oil pressure issue on severe slopes is why I hooked up the factory supplied low oil pressure switch on my PT180. I used a electronic siren (like some manufacturers use when you get off the seat with the PTO engaged). I have never noticed it come on when using the machine, but it is nice to know I have a way to determine if I lost oil pressure.
This Kohler engine list max angles of cont 20, intermittent 35. http://www.kohlerengines.com/engines/onlinecatalog/pdf/tp_2339_d.pdf
/ Skid steer or 1460 #34
I'm a little late to this discussion but will throw in my two cents. First, let me say that I love Power-Trac's I have three (multiple properties). I also have a compact track loader (skid steer with tracks) and a mini excavator. As others have mentioned, it depends on what you want to do.
The Power-Trac has many advantages. But it isn't NEARLY as strong as a compact track loader (CTL) when it comes to pushing, digging, or lifting. I recently saw a guy dig out an in-ground pool completely with a CTL. Frankly, I was shocked. He is a subcontractor for the pool company and digs all their pools with a CTL. You can pick up a nice used Japanese made Takeuchi CTL for significantly less than the cost of a 1460 and it's a FAR better made machine.
The problem with the skid steer is stability. If you get it on a small slope and raise the bucket, it can turn over easily. A compact track loader is a little better but nothing like the Power-Trac. As with most machines, everything is a compromise. If you intend on keeping the 1850 for specific duties, and add another machine, I would choose a machine that complements the 1850's strengths and weaknesses. For example, I wouldn't choose a skid steer or compact track loader for mowing on a slope. However, I wouldn't choose an 1850 for the purpose of any digging. I would list out the most frequent and important uses for my current AND likely future needs. I'd focus on 80/20 and select a machine that would work best 80% of the time. For the other 20%, I'd make do or rent a machine.
For the record, of all the machines I have, including a compact tractor, my favorite machine by far is still the good ole 425. It does a LOT for what it is. It's relatively cheap (especially if you buy used), fast, fun, doesn't tear up the yard, versatile and brings a smile every time I use it. I'm not suggesting you consider a 425...just adding context for others reading this post.
/ Skid steer or 1460 #35
Hey all
So my wonderful 1850 is really showing wear. Last night i foend the holes connection the rollover arm to the connecting plate elongating. Probably what will happen is nect year i will take the machine off line and tear it down and improve it bur that said i brought up adding a 1460 to the fleet. I would keep the 1850 but put more abuse on the 1460. But tHe wife asked the hard question. Why not a skid steer. I need to check with terry but i think my implements cross over but outside of that i didnt have an answer because i have never has a skid. Any experienced thoughts?
One question that is on my mind, how many hours on your PT1850?
/ Skid steer or 1460 #36
Hey all
Never asked, but can you post some pictures of the elongated holes?
Dunno on hours. I think i have had the machine 13 years so 750 to 1000 hours total Pictures forthcoming. Marrt great comments.
/ Skid steer or 1460 #38
Woodland, your original question is similar to comparing a fork to a knife, just can't do it. I'd say that each machine would compliment the other as each excels in different tasks. Years ago Bobcat was selling "the Bobcat system" and that was a mini ex and a SS or CTL. Each machine had its capabilities and strong points. Imho, there's not enough difference between your proposed choices to warrant the expenditure.
Now I've followed your post over the years and am under the impression that you are dealing with hilly to steep ground, but beyond that, I'm only generalizing and selecting another man's tools with any certainty of his needs is just silly. With that said, get whatever you like (or your wife approves of) it's just a machine that can always be sold or traded. I'm the last guy in the world to talk someone out of another toy, er tool.
(What a rambling bunch of BS:laughing:)
I get by myself with a massive SS, a small excavator and my M9540 with a bunch of various attachments for each. :thumbsup:
ALLISON TRANSMISSION (A55745)
ALLISON...
2025 JMR 40in Single Cylinder Brush Grapple Mini Skid Steer Attachment (A59228)
2025 JMR 40in...
2015 Ford Transit Connect Passenger Van (A59230)
2015 Ford Transit...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59905)
2017 FREIGHTLINER...
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
