Hello All,
I have had a problem with the hydraulic oil in my skid steer loader for a while now. I have changed the oil but that was to no avail. The oil returned to its milky white state. Over the past few weeks the machine has been sitting idle and all of a sudden I noticed a puddle of hydraulic oil forming below the machine. On closer inspection the top of the hydraulic tank was covered in a mix of water and oil. So I cleaned the top of the tank and within a few minutes oil started to reappear. It now is obvious that there is a small crack where the filler pipe connects to the oil tank/resevoir. So anytime it rains water is getting into the oil.
So now that I know where the problem is originating from I want to fix this leak and change all the oil in my machine. Does anyone have a procedure for doing this. do I need to remove all piping and purge them.Or could I just drop the oil , put in a temporary rinse oil for a few minutes. Then drop the temporary oil and put more fresh oil into it. I am good mechanically but have never worked on a hydraulic system this complicated so I don't want to take on something which I am not capable of doing. My Uncle in law is a very good mechanic and I may be able to get some help off him.
In terms of fixing the leak, is rewelding the only option (obviously with tank drained and cleaned) or is there any other product which I could use.
Any advise is greatly appreciated..
Ronan
Ronan
