skid shoe
   / skid shoe #1
eteagle
Illinois
JD 3300
I'm reluctant to reveal my ignorance but can someone tell me what a skid shoe is on rotary mower and back blade? What do they do? Can they be added to the implement?
Ernie
   / skid shoe #2
SEEMS TO ME THEY ARE SOMETHING THAT WOULD ATTACH TO YOUR BALD THAT WILL SLIDE OVER THE GROUND AND MAINTAIN A CONSTANT DEPTH FOR THE MATERIAL YOU ARE TRYING TO MOVE ie SPREADING GRAVEL TO A 4'' DEPTH .
HOPE THIS HELPS I'M NOT SURE IF I'M RIGHT JUST HOW IT SEEMS THAT IT WOULD WORK TO ME THANKS JRAY
   / skid shoe #3
Yea, you put these on your back blade and you can only lower it so much .That way when you use it to plow snow with you don't have all of your gravel driveway in your backyard come spring time
Bartman
   / skid shoe #4
I think a skid shoe on a rotary cutter is different than what's on a blade or rake. The front shoulders of the housing of the rotary cutter -- the lower edges of the enclosure on the front corners-- get a lot of wear because users drag the cutters thru uneven ground and over rocks, stumps, etc. These corners have wide, thick metal welded on the bottom -- they're what's called skid shoes on cutters. If you wear them out, you're really working hard on rough terrain.
jim
Toro ProCore 864 Series 64in Turf Aerator Tractor Attachment (A51691)
Toro ProCore 864...
2022 UTILITY FS2CHA 48FT FLATBED TRAILER (A53426)
2022 UTILITY...
ATLAS 84" BOX BLADE (A51243)
ATLAS 84" BOX...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2014 Ag Spray Schaben Sidedresser (A53473)
2014 Ag Spray...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
