Skid Plate 2305
   / Skid Plate 2305 #1
bird1968
Canada NB
BX24 after years of BX22
I got this one done today!
If it can help someone, protect their machine, here it is.
Bird
   / Skid Plate 2305 #2
bird,
Very nice! Can you take and post some more close up pics so we can see the relationship of the filter and pto to the skid plate?
   / Skid Plate 2305 #3
Nice job on the skid plate, but I am more interested in your cab. It looks like a Curtis. How do you like it, how tight does it seal up?
   / Skid Plate 2305 #4
bird1968,
You probably have to remove this skidplate to use the mid PTO, right ? Or does that cover looking piece come off and the PTO shaft go thru the hole ?
Thanks,
Red
   / Skid Plate 2305
Hi Red,
The mid PTO can be used with the skid plate (goes thru the hole), for a snow blower, but the MMM I'm not sure yet/ clearence.
check out, how it's does mount.
The tractor is not mine, it's JonnyDeer..from the same city, he can/shall anwser your questions on the cab.
Thanks,
Bird
   / Skid Plate 2305 #7
I want one. But - I need to know there's no interference with 62C MMM, AND mid PTO is usable for front mounted snow thrower without removing skid plate.
   / Skid Plate 2305
The front blower will work, but the MMM has not been tested.
The skid plate could still be moved backward, to help clear the MMM, but there is the linkage for parking brake that would touch the skid plate.
here's another shot.
   / Skid Plate 2305 #9
Can you tell me where the skid plate is secured in the back?
   / Skid Plate 2305
As you can see here
it's bolted onto the existing hole, two washers are needed for spacers. Once bolts is tighten down, it's a nice fit.
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2013 Ford Edge Limited AWD SUV (A51694)
2013 Ford Edge...
2017 TRAILSTART 40FT DUMP TRAILER (A52576)
2017 TRAILSTART...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2014 International Sweeper Truck (A52377)
2014 International...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
