skid or tractor wheel
   / skid or tractor wheel #1
Rhon
Bronze Member
Maple Valley Washington
New Holland TC18
I need to replace one of the rear wheels on my TC18 and NH wants $205 apiece. Same size skid wheels are about half the cost. How much of a difference is there between the skid wheel and the tractor wheel? Can I swap them out? What do I need to look for...
   / skid or tractor wheel #2
If they are the same size. The skid loader tire is usually a heavier tire. I think it should work.
   / skid or tractor wheel #4
if you have the optional 4x4 / MFWD for that model, you need to make sure you keep correct ratio of front tires to back tires. if fronts and back tires are out of ratio, you can do some costly damage to the drive system of the tractor.
my general blah of what is what...
tire = rubber piece
rim = metal center
wheel = rim and tire
pending on tire type (R1 / agriculture, R3 turf, R4 industrial) you may be stuck to a certain type of tire, due to rim width. normally you can swap R3 / R4's on the same rim. but R1's need a different rim.
I understand... the rim needs to be replaced. I have the R4 tires on it. The rim is rusting so I thought I'd replace it.
   / skid or tractor wheel #6
If the offset is OK then I would go for it...Skidders take more abuse than most tractors..
That sounds good. Guess I'll do some more measuring to make sure they're the same.
2013 GMC Yukon Denali 4x4 SUV (A51694)
2013 GMC Yukon...
50ft Fuel Line (A51573)
50ft Fuel Line...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
1999 FORD F550 BOX TRUCK (A52577)
1999 FORD F550 BOX...
2025 JOHN DEERE Z325E LOT NUMBER 87 (A53084)
2025 JOHN DEERE...
2025 New/Unused LandHonor Plasma Cutter (A51573)
2025 New/Unused...
