sizing a box blade to a 75hp farm tractor
   / sizing a box blade to a 75hp farm tractor #1
kroeter
Darlington, PA
John Deere 5420
Can I attach a common 5 or 6ft box blade to a 75hp farm tractor? Most I see are category1 3pt hitch. I assume mine is a cat2? I see threads about sizing a box blade to a small utility tractor like a 25 or 35 hp tractor but I don't see any mention of connecting a box store variety box blade to a large tractor. I assume it can be done. Mainly I need a box blade for 700 ft farm lane that is a limestone driveway that is past due on maintenance with potholes. I need to use the scarifiers to dig up the several years of pushed in clean limestone down 3 inches and level out the lane and dig up the potholes before probably ordering a couple loads of 2a limestone on top. I hear there is no use adding it now without first digging or roughing it up down to the level of the pothole. All the box blades I see on the market talk about small tractors. I don't have a small tractor. can I still buy the common 6ft box blade on the market and will it serve my purpose. I don't intend on going backwards with it.(I suspect that would overpower and bend the box blade connection framework)
   / sizing a box blade to a 75hp farm tractor #2
I think your going to trash a 5-6' box blade. You need a cat 2 7-8' box blade( depending on your rear wheel width). Have you looked at craigslist and facebook marketplace?
   / sizing a box blade to a 75hp farm tractor #3
For your tractor, I would not consider anything less than 1000 lbs. And yes you might not even be able to connect to a cat 1 hitch. The eyes may be too large for a straight cat 1 hitch,
Don't even bother looking at anything in a cat 1 size. 7' minimum, up to 8'.
Good luck.
   / sizing a box blade to a 75hp farm tractor #4
All of my implements are Cat 1. Prior to my NH WM75 I had a NH Boomer 8N 50 hp tractor with a Land Pride QH15 Cat 1 quick hitch. To avoid having to by new Cat 2 implements I put the quick hitch on my WM75 when I traded in the Boomer 8N. Now I can easily use my 6' Land Pride box blade and 6' tiller behind the WM75.
   / sizing a box blade to a 75hp farm tractor #5
Go with whatever is as wide as your back wheels and built from 1/2" plate all the way around for structural integrity. Isn't the Workmaster 75 like 80" wide? A heavy 7ft BB should be perfect for it. Too bad you aren't close to PA, I would sell you my LandPride 2584 BB so I can downsize to a 72". My tractor just isn't heavy enough to pull a full 84" BB uphill.
2018 INTERNATIONAL LT625 SLEEPER (A51219)
2018 INTERNATIONAL...
2008 STEPHENS 220BBL CRUDE OIL TRAILER (A50854)
2008 STEPHENS...
2017 FREIGHTLINER CASCADIA 126 SLEEPER TRUCK (A51222)
2017 FREIGHTLINER...
2024 AGT KFE-20 2,000lb Electric Forklift (A50322)
2024 AGT KFE-20...
New JMR 78" Double Skidloader Grapple (A50774)
New JMR 78" Double...
15 FT Trailer (A50322)
