Price Check Size? Price?
   / Size? Price? #1
Anonymous Poster
Epic Contributor
Found you yesterday and what a relief to see other idiots have the same questions I do. Real life Tractor Talk. I currently am considering a Kubota. Am thinking M4700 - M5400 low hour, clean, used or NEW M4900 - M5700. I currently own 25 acres and play at farming, grow big garden, raise a few Angus beef cattle. I soon (3 yrs) will retire and play at it more. Want to have a good New or Low Hour Used tractor to last me thru the rest of my years. I currently own , and have for 15 years a Ford 1900, 32 HP, 4WD. Has been a great little tractor and can't say anything bad about it.
Are the 4700, 5400, 4900,5700 Kubotas the same physical size? If so I want all the HP I can afford. 4WD is a must as my little tractor works like a 45 HP that is all I will consider. Do all of you like the Kubota loader or an aftermarket brand better. As many of the messages I read yesterday on your log I am having trouble finding a Local Dealer in which I can put my trust. All are pricing within $250 of each other and I don't know how much markup is in these things but I haven't gotten serious with anyone yet in the form of an offer. They all seem very high to me at the $26K+ range. If any of you have comments, questions fire em off at me. If you know of a reputable dealer in the Middle Tennessee area let me know.
   / Size? Price? #2
Lem, since I own a smaller Kubota, I don't have the answer to your questions, but suggest you check out http://www.kubota.com for specs on the different models, and also click on the banner for Carver Equipment and look at the prices he posts for different models. That'll give you a good place to start. And I've forgotten the dealer's name, but there have been some favorable messages posted about a dealer in Tennessee that you might find using the "search" feature on this forum. Kubota.com, as well as this forum, has some listings of dealers around the country.
Bird
   / Size? Price? #3
Lem,
By the sounds you have plenty of tractor time under your belt,so go with your gut feeling and have fun making that purchase./w3tcompact/icons/wink.gif
Stay safe and /w3tcompact/icons/cool.gif
Thomas..NH
   / Size? Price? #4
Hi,
Yes, the M4900, M5700 and M6800 are all about the same size. I have the M6800SR. All three are fully sync transmission, but used 1999 and back will not be. The new ones also have the shuttle shift on the dash and that is a very nice feature. Look carefully at prices. I bought an M6800 with LA1002 loader and quick connect kit for bucket with tires loaded with antifreeze (non/toxic) and 50 hour service included for $27,000. The M5700 should be about $1500 less and the M4900 should be about $24,000.
The M Series are really nice tractors. The M6800 has adjustable 3 point links which are worth the $1500 by themselves plus a much heavier duty front and rear axle and is the only one in this series that has a differential lock for the front and rear axles. The front tires are large enough (24 in wheels) that it will go over a lot of small drainage dishes and washes that smaller front tires can's handle. The tractor with tires loaded and loader weighs a little less than 8000#, yet the tires are wide enough that the pounds per square inch of contact area is comparable to many of the smaller compact tractors. The large tires have a lot of traction and ride well.
The Kubota loader is the ONLY way to go. It is a really nice loader and everything fits and works together. With the quick connect bucket, pull two pins and you can use a hay spear or pallet forks with the loader. Look at the mounting on the loader to the tractor, and you will see that no aftermarket is as well fitted to the tractor.
The M6800 has a 4 cylinder that starts and runs everytime. It has as much power at idle as my last 40 HP tractor had a PTO speeds, yet it turns in an average of about 1 gallon diesel consumption/hour.
The next step up in the M Series gets a lot larger wheelbase (and nicer loader), but I did not want to lose the maneuverability of the M6800.
Search this site and the archives under M6800, M4700, M4900, M5400, M5700 and you will find quite a bit (all good) written about these tractors. Good Luck.
p.s. Register and then the system will keep track of the messages you have read, send you an email when someone answers you, and let you keep up with things easier while you are looking. There is no downside to registering.
   / Size? Price? #5
Dittos, Bird
I believe tractorsmart.com is the other site in tenn. Carvers jack rabbit pages also for no nonsence prices
   / Size? Price? #6
LEM,
With 15 happy years of tractoring on a Ford...why not look at New Holland also? They at least deserve a look and the ergonomics are preferred by many!
Good Luck and happy hunting!
JimBinMI
We boys and our toys!
   / Size? Price?
The 1900 has served me well and can say no bad about it. Have looked at the 2120, but feel I need more HP. The new TN 55, 65, 70 series is just too big for my needs. As I saw someone else say in this forum I am also a little leary as to the direction of NH, Case, Ford or whoever they are aligned with today. I heard by next year the 1920,2120 and rest of compact line will be replaced by the BOOMER line and or TC compact line. Those tractors are a little too radical and YUPPIE looking for me. Thanks for your comments
   / Size? Price? #8
LEM,
You're right, most agree that they are the best looking tractors on the market. Consider the front slope that causes you to see better off the front and especially when doing loader work...as reported by owners using loaders with the new New Holland tractors.
By the way, CNH - Case New Holland is the World's largest manufacturer of agricultural equipment! /w3tcompact/icons/cool.gif
Good Luck, JimBinMI
   / Size? Price? #9
LEM,
I bought a 2120 late this spring. My dealer told me that the 1720 & 1920 are not in production any more. He stated to me that the TC45 would not replace the 2120. As far as power from the 2120 I have done a lot of loader, backhoe, and rear blade work and never lacked. I have not used the PTO yet. I have a chipper that is hydrualic feed by the tractor hydrualics and the knives and blower are run from the PTO. This is really going to be a good test to see if it has "power". I will be using the chipper hopefully by the end of the month.
I didn't get a TC45 because there was a waiting period and it was new to production and there was no backhoe avalible at the time. Personally I don't like getting something in the first year of production if I can help it. The 2120 has been a proven model (been around for about 10ish years?). I'm sure that someday the 2120 will also be replaced. The TC45 is a really, really nice tractor. Maybe I should have waited to get the TC but I can always trade. My dealer aslo told me that the resale value of the 2120 is really good. He told me that he can't forsee the future but that I will be likely to get what I bought it for.
I have been using the tractor for about 50hrs. If you have any questions let me know.
Derek
   / Size? Price? #10
Lem ,
Back in the 70's Triumph introduced the TR7 (with a wedge shape) with the slogan "The shape of things to come" well they were right and I believe NH is definitely on the right track. My local Kubota/NH dealer told me Kubota is frantic about the NH changes and will soon be making their own. (Uh Oh guys Orange tactors with plastic hoods!!!)/w3tcompact/icons/shocked.gif /w3tcompact/icons/smile.gif
2021 Liebherr L556 (A52748)
2021 Liebherr L556...
BOBCAT 260 WELDER/GENERATOR (A52472)
BOBCAT 260...
2019 Ram 2500 Pickup Truck, VIN # 3C6UR5DL0KG545677 (A51572)
2019 Ram 2500...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2014 Club Car Electric Golf Cart (A51694)
2014 Club Car...
