Tractor Sizing size of sicklebar mower?
   / size of sicklebar mower? #1
larch
Pembroke, Va
Yanmar 1601D
First, Thanks to all on this forum for helping me to decide which tractor to buy. Been lurking for about two years now.
I know you folks have an answer to this.
Which size sickle bar mower would you recommend for my 1601D? I've got a loader on the front and can add wheel weights if needed.
Thanks in advance.
   / size of sicklebar mower? #2
You need as small as you can find, probably 7', 6' if available.
Thanks for the reply. A local tractor place said it would never handle a 7 foot. Too light?
I guess I'll start looking for a 6 footer.
Any thoughts where to start looking?
   / size of sicklebar mower? #4
Mind me asking what you will be using the sicklebar for? Suitable for haying but would think a mower better suited for just cutting. Very high grass might be the exception.
   / size of sicklebar mower? #5
These folks make one, although much too pricey for me.
They used to carry one for about $1100, but I don't see it on their website anymore. Maybe you should call them.
   / size of sicklebar mower? #6
Before Ford's patent on the 3pt hitch ran out, there were pull behind sicklebar mowers. I've seen usable units sell for only a couple of hundred because they are outdated equipment. It might be an option.
Thanks for all the replies fellas. I have a steep drive with uphill slopes on both sides. The growth is getting to be too thick and sticking out into the drive. Need to cut it down some.
   / size of sicklebar mower? #8
I think a 5 ft. would be hard to handle with a 1610. Unlike other mowers a sickle mower can be cut to any length. Well it must be cut to the correct run out on the sickle. Be aware that the bar can hang and even at 5 ft. to the right side of the tractor it can really jerk the tractor around. Be sure that a break away release id part of the bar assembly. They are very handy for mowing where you cannot drive the tractor. Around a pond over the edge of a bank. Also be aware that it is more fragile than a rotary cotter. I have broken dozens of teeth and bent guides otherwise destroyed part of the bar assembly trying to cut rocks and bushes to large for the mower.
Thanks Normmm and all others for all the good advice. I didn't know that one couldbe cut to length. Makes my choice a lot easier. Mostly weeds and a few small saplings less than 1/2 inch. Should handle it just fine.
Thanks again.
Dennis
2015 Chevrolet Express Passenger Bus (A50323)
2015 Chevrolet...
2001 Great Plains 3N-3010P-4875 Grain Drill (A50657)
2001 Great Plains...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
5K ANNULAR BLOWOUT PREVENTER (A50854)
5K ANNULAR BLOWOUT...
71055 (A49346)
71055 (A49346)
