Single Line Cylinder
   / Single Line Cylinder #1
Believer
I have an lift that has just a single line to the cylinder, i.e., pressure up, gravity down. My tractor, NH TN75, has a setup for front end loader with two spool valves and a third spool valve. If I just hook one line in to any valve, to let pressure off one side opens pressure to the other side. But the other side doesn't have anywhere for the fluid to go, so the internal pressure relief valve has to be opening. Is that ok? How else can I hook up a single pressure line? Thanks.
   / Single Line Cylinder #2
What you have is called a SA (single acting) cylinder. The way you have it hooked up is fine, the PRV (pressure relief valve) is doing it's job and it's only for a few seconds so no harm will be done.
You can get a valve specifically for operating SA cylinders, or run a hose from the open port opposite the one the SA cylinder is plugged into and hook it to the sump...but I wouldn't bother.
2022 Toro Workman 07921 Electric Utility Cart (A51691)
2022 Toro Workman...
2003 Ford E-350 Cargo Van (A51692)
2003 Ford E-350...
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
Charlotte County BOCC Odom Reads 124977 miles Year: 2012 Make: Ford Model: F-350 Vehicle Type: (A53422)
Charlotte County...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
