Single lever loader control
   / Single lever loader control #1
ronbrent
Cavendish, Vermont
New Holland 2120 TLB,Ford 1985 2110/Loader, John Deere 755/Front Mounted Snow Blower,International 500E Crawler/4n1Bucket
Trying to install a single lever loader control in place of the 2 lever on my 2110 Ford. It is a NOS for a 2120 Ford around 1988. It is a Zexel stamped 46224 on the ID tag, which states *** No 307800-0721, *** Code 34001-3541. I don't know if it needs or I should say they use a power beyond bushing in the power beyond connection which is the one farthest away from the operators position. The center connection I think is the inlet, with the return being closest to the operator. Any info will appreciated.
   / Single lever loader control #2
If you are talking about a joy stick valve you will have 7 ports with PB.
There will be an IN port, an OUT port, a PB port, and 4 work ports.
2014 Club Car Electric Utility Cart (A51694)
2014 Club Car...
2005 TerraGator 8104 (A55301)
2005 TerraGator...
12in Mini Excavator Tooth Bucket (A52377)
12in Mini...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
2012 John Deere 850K Crawler Tractor Dozer (A52377)
2012 John Deere...
2021 HAMM HD+9I VO SMOOTH DOUBLE DRUM ROLLER (A52706)
2021 HAMM HD+9I VO...
