single-bottom plow
   / single-bottom plow #1
Anonymous Poster
Epic Contributor
I have a Ford 1215 4WD compact tractor, about 14hp. Can anyone tell me if I can pull a single-bottom moldboard plow? Thanks in advance for any information you can provide.
   / single-bottom plow #2
Bubu, it depends./w3tcompact/icons/wink.gif What kind of soil do you have, sandy, clay, etc.? How hard is it? What's the moisture content; you may be able to plow when it's slightly moist, but not very well when it's dry. And how big a moldboard are you considering? How deep in the ground do you want to go? I'm going to guess that you would be happiest with a 12" moldboard, although they may be harder to find than a 14". If your ground is not too hard and/or you don't try to go too deep, the 14" may work well for you. But the simple answer to your question is, yes, you can pull a moldboard plow./w3tcompact/icons/smile.gif
Bird
   / single-bottom plow #3
BuBu, Make sure you can mate the plow to your tractor before you plunk you money down. On small tractors some small plows can't be positioned so that the right rear wheel rides in the furrow so that your not driving over what you've already plowed. I tried a used older 2-12 Ferguson plow on a Ford 1910 and the plow wouldn't go far enough to the right. I had to haul it back myself. An older JD 2-14 plow does work on my rig,but it is all it can handle.
RCH
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2018 RoGator 1100C (A52128)
2018 RoGator 1100C...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 GENIE GTH-5519 TELESCOPIC FORKLIFT (A51242)
2019 GENIE...
2015 Terex PowerScreen TrakPactor 320 Crusher (A50322)
2015 Terex...
MAHINDRA 5545 TRACTOR (A51243)
MAHINDRA 5545...
