SIngle axle utility capable of 2500lbs payload?
   / SIngle axle utility capable of 2500lbs payload? #1
rbstern
Platinum Member
GA
LS MT225E, Yanmar 2210
I have very modest trailering needs that have been served by a light duty 4x8 folding trailer. It has done well for me hauling single ATVs, a golf cart, lawn tractor, furniture, light loads of lumber, cement, landscaping stuff, etc.
Last year I bought a cabin, acreage and a Yanmar 2210. I don't anticipate trailering the tractor, except in the event I need to bring it somewhere for service I can't do myself, or on the rare occassion I might be asked to do some box blade work for friends. I want to replace my folding trailer with a slightly bigger and more rigid utility trailer, so I can haul more stuff from the local building supply centers (25 to 50 mile roundtrip), occassionally transport stuff to/from my primary home (150 mile roundtrip), and to use around the property for landscaping and building projects. For anything other than the tractor, I would probably be happy with a 5x10. But I find myself wondering if I went with a 6x12 with a heavy duty axle, could I occassionally (once or twice a year), safely transport the Yanmar and my box blade, a total of about 2500 pounds? My tow vehicles have 7000+ and 5000+ tow capacity, so no problem on the pulling end. I don't want to move up to a dual axle trailer just for the tractor. It's just not enough of a pressing need, and I like how much easier it is to deal with a single axle trailer.
Would welcome any opinions.
   / SIngle axle utility capable of 2500lbs payload? #2
I have a Top Hat 5x10 tilt with a 3500lb axle. It weighs 990lbs alone. I routinely carry a MF1230 4wd tractor or a Kubota u17 excavator on it. The tractor is fine, but the excavator weighs 3400 putting me about 900lbs over. Even then the leafs aren't bottomed but I go very slow when doing that.
The biggest complaint is the placement of the axle. Being a tilt, it is centered fore/aft. If it was 10% biased to the rear, it would keep the tail sway to a minimum. It's a bit more difficult to get the load centered properly on a smaller single axle.
   / SIngle axle utility capable of 2500lbs payload? #3
Yup, watch axle placement. You want about 10% tongue weight. Meaning....3500 lb. load needs about 350 lbs of it on the ball.
If you want to haul the tractor, find a trailer that is balanced properly with it loaded. Other types of loads can be shifted forward or back if need be.
   / SIngle axle utility capable of 2500lbs payload? #4
Legally in most states once you hit 3,000# you must have brakes. Its possible like others said that a 6x10 or 6x12 trailer will do the job. They usually weigh in under 1,000# and a 3,500# axle will get you the 2,500#'s you need.
Balancing the load is going to be the issue.
For me though there is no way I would tow anything more than a golf cart or riding mower on a single axle trailer. A tire failure with a top heavy load on a single axle trailer can get fatal real quick. Just not worth it to me.
Chris
   / SIngle axle utility capable of 2500lbs payload? #5
I have a 6 x 10' trailer that I put a 6000# mobile home axle under it. I threw on a couple 11'x32" oak logs on it and a couple smaller hickory logs. I have load range G tires on it and hauled these logs to the mill and it pulled like a charm. I wouldn't see any harm in a 6'x12' trailer having a single heavy axle under it. Of course my tandem axle trailer was full of wood at the time or I would have probably used that, but I was surprised how well it worked.
Chris
I have both single and dual axle boat trailers. Couple years ago, had a tire on the single axle come apart while on I-85 at about 60mph. Trailer, boat and some cargo weighed in at about 2750. Was towing with my Ford Explorer Sport Trac (short bed/Explorer based pickup). Was a complete non issue. Except for the noise of the tire peeling off the rim, and the rim on the pavement, there was no fuss. Trailer never moved out of line. I attribute that to appropriate load distribution, as others have suggested. Unless something is unbalanced, it will stay where it is supposed to stay. The tractor would have a higher CG, but that only comes into play if sway becomes an issue.
   / SIngle axle utility capable of 2500lbs payload? #7
The only way I would pull a single axle trailer with a tractor on it,, is if the tires are airplane tires 22+ply,, I agree with Chris you blow a tire at 35 mph you are in for a rough ride,, I have been there once.. Lou
   / SIngle axle utility capable of 2500lbs payload? #8
A boat trailer with a long arm (distance from ball to axle) and a very low CG would be a non event 999 times out of 1000. Now a utility trailer loaded with a high CG and its short arm is another beast.
Chris
One other possibility would be to hoist the box blade into the bed of my pickup with a boom pole, to save about 450 pounds of weight on the trailer. Certainly not as convenient, but doable for the rare occassion where I need to take the box blade somewhere.
   / SIngle axle utility capable of 2500lbs payload? #10
i'll never haul a heavy load like a tracotr on a single axle trailer agin. been there, done that with my yanmar 1700 and it was a dangerous affair. At the time part of the issue was I owned a toy truck.. a ranger.. still... if it's worth doing.. it's worth spening a couple hundred more and doing it safe..
IMHO
John Deere 4052M Tractor with 400E Loader, 3rd Function, Hydrostatic Transmission (A44789)
John Deere 4052M...
Pallet Of Vehicle Seats (A42745)
Pallet Of Vehicle...
ALL-STEEL CARPORT W/OPEN SIDEWALLS (A45046)
ALL-STEEL CARPORT...
2014 MACK GU (GRANITE) (A45046)
2014 MACK GU...
2011 PETERBILT 365 (A45046)
2011 PETERBILT 365...
2019 Ford F-150 Pickup Truck, VIN # 1FTFW1E46KKD75859 (A44391)
2019 Ford F-150...
