simplicity....
   / simplicity.... #1
gravelman
Platinum Member
NH
Kubota 2650
Hi kids...this is gravelman from Hopkinton Ma. i know ride on mowers are not subcompacts but...anyone have a simplicity ride on that is new...cannot put gas in the thing unless you have all day to do it.....not sure what to do. But, im also looking for a John Deere Model A 1950's vintage...in good shape and running. Any help grealy appreciated. thanks
   / simplicity.... #2
Further explanation of the issue would be handy. What do you mean you can't put gas in unless you have all day? What happens when you try fueling it?
   / simplicity....
my apologies..you are correct.... the tube that goes from the cap down into the tank is too long....does not allow enough room for the gas to freely flow into the tank. I have since talked to a tech at Simplicity and he says the dealer will replace the tank...hmm, when i talked to the dealer they said i was pretty much stuck with the condition....i guess you have to push to get anythng done these days.... and i will thanks for getting back to me..i hope this helps???
   / simplicity.... #4
Sounds like it isn't venting properly. I'd let them have at their fix first, there may be a redesigned/better part. If their fix doesn't correct the problem, there are a ton of ways to add a filler vent to allow the air to escape as you fill it. But yea, I would press them for a fix first.
Flatbed Utility Trailer (A52377)
Flatbed Utility...
UNUSED LANDHONOR PR-12-72W 72" HARLEY POWER RAKE (A54757)
UNUSED LANDHONOR...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
New Holland TS 75 Front Loader Utility Tractor (A53421)
New Holland TS 75...
2004 Ford F-250 Liftmoore 2,700 LB 1 Ton Crane Service Truck (A53422)
2004 Ford F-250...
