Simplicity Snowblower
   / Simplicity Snowblower #1
stevecjohnson
Its snowin in Denver and my Simplicity 760 is acting up. Engine is fine. Problem is the crank that turns the directional discharge chute doesn't stay in position. It wants to move back to the left unless its held. The mechanism is a worm screw (gear) on the end of the cable crank that rotates the gear attached to the chute. I like it to crank easy because when I'm battling mother nature, I don't want to fight a stiff crank. Otherwise its a super machine about 15 years old. Has a Tecumsah 8 horse. Any suggestions are welcome. Steve
   / Simplicity Snowblower #2
I have the same problem and althogh it isn,t pretty,have wrapped a bunge cord around the shft several times.If it still moves on you,wrap it some more.
Tighning the clamp bolt doesn't seem to work .It either becomes to tight or loose.
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
KUBOTA M6800 UTILITY SPECIAL TRACTOR (A51406)
KUBOTA M6800...
2016 Ford F-550 4x4 12FT Landscape Dump Truck (A51692)
2016 Ford F-550...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
1266 (A50490)
1266 (A50490)
2014 John Deere 244J (A47477)
2014 John Deere...
