Mowing Simplicity Prestige (Not)
   / Simplicity Prestige (Not) #1
nebraskasparks
Northern Illiniois
2010 Kubota L5740 HST and JD X734
Traded my JD X500 in for a Simplicity Prestige this May. Offloaded the mower and started it up and engaged the deck...and it quit. This happened 7 times and they took it back to the shop. Safety switch was installed/broken at the factory. New switch everything is great. Fantastic cut compared to the JD deck. Love the power steering and shock absorber ride. That lasted 10 hours until I moved the throttle to idle and the throttle quadrant came out of the dash. Over center clips must not have been clipped in I thought. Clipped it back in. Wife mowed the following week and same thing happened. Back to the shop...new throttle quadrant that doesn't fall out of the dash. That's a good thing. Wife complaining about not being able to set the parking brake without full leg extension, same thing for me but the power steering and the shock absorbers make for a great ride and the deck cuts so well that it's something we can live with. At 48 hours on the clock...the mower quits dead in its tracks. Oil, fuel, battery all good. Off to the shop to find out wires to the electronic fuel control had come loose? Getting tired of having the new machine in the shop while the grass grows. At 55 hours I'm blowing off the deck when I notice a spring laying on the deck and that the deck wobbles. The front of the mower deck has two welded pieces that the mower hangs from and the left hangar is snapped perfectly at the weld line.
Is this the new Simplicity or did I get the lemon this time around?
   / Simplicity Prestige (Not) #2
I don't know if it is new or not.
I agree with you on the cut. I haven't seen a mower that cuts as well as a simplicity does. I think it is the free floating deck. (but I'm no expert)
Although my mower is older and a lower model (Regent)... I too question there quality.
My frame is cracked, and now my PTO clutch doesn't work.
It's a love hate relationship. I'm just wondering what I am going to do about it.
   / Simplicity Prestige (Not) #3
I think quality control has been an issue in recent years.Just have to work through the gremlins.With the rear roller decks you have to be very careful not to catch the rollers,especially when backing up as it puts extreme stress on the mechanism,even the front mounts.
2016 JLG 3248RS 32ft Electric Scissor Lift (A50322)
2016 JLG 3248RS...
2011 John Deere 844K Articulated Wheel Loader (A50322)
2011 John Deere...
2022 John Deere S780 Combine (A50657)
2022 John Deere...
RIGID 150 PSI AIR COMPRESSOR (A50854)
RIGID 150 PSI AIR...
100 GAL FUEL TANK (A50854)
100 GAL FUEL TANK...
2015 CATERPILLAR 289D SKID STEER (A51242)
2015 CATERPILLAR...
