Simplicity Hydro Fluid
   / Simplicity Hydro Fluid #1
mytoys
Bronze Member
Southeast CT
Kubota L5030 and KX161
I have an 80's, 12 horse, simlicity lawn tractor with a haydrostatic trans. I think the model is a 7112. In any case, I keep having to drive 20 mi to the similicity dealer and order hydro fluid in guarts, then go back and pick it up when it comes in. This is tedious. Is anyone aware of a substitut for the hydro fluid for this? It's red in color. Perhaps some type of auto transmision fluid? I remember an old Case backhoe I had used dextron as a substitute. Any help is appreciated.
   / Simplicity Hydro Fluid #2
I don't know for sure on the Simplicity but a large portion of hydrostatic transmissions in lawn mower/tractors use ATF. I have a late 90's vintage Craftsman with a Pearless hydrostatic trans and it takes ATF. You would probably be safe with Dexron III / Mercon in it. ATF fluid is afterall a hydraulic oil.
   / Simplicity Hydro Fluid #3
You can substitute Type F transmission fluid, but don't tell anyone I told you...
Thanks much, I appreciate the help.
2017 International Distributor Truck (A52377)
2017 International...
2003 John Deere 310SG (A47477)
2003 John Deere...
2005 PETERBILT 379 DAYCAB WINCH TRUCK (INOPERABLE) (A53843)
2005 PETERBILT 379...
RIDE AND DRIVE INFO (A50775)
RIDE AND DRIVE...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2016 CATERPILLAR 336FL EXCAVATOR (A51246)
2016 CATERPILLAR...
