Simplicity Contender XT
   / Simplicity Contender XT #1
dvan1966
NW. Ohio
Kubota B6200DT
I've been looking at zero turn mowers. My first one. Mainly the Simplicity Contender XT and Gravely ZT HD with 52" deck. I haven't been able to find many reviews on the Simplicity, found a few on the Gravely and they were not as good as I thought they would be.
Does anyone have any input on the Simplicity Contender? I'm kind of drawn to it based on the suspension and the trans axles are the ZT 3200 series vs 3100 on the Gravely.
   / Simplicity Contender XT #2
I don't have input on the Contender but do on the Citation XL and the ZT2500 as I have both.
The Citation XL I have is a 27hp 61" mower deck with about 100hrs on it. We bought it last season to replace the Ford 1900 with a 72" mower deck that was overkill for our 4 acres of grass cutting. It was simple too much for what we needed. And the wife would not run it. The XL has been very easy to use and cuts our combination house grass and field grass well and is a very even cut considering it's 61" across. If I cut sideways on the hill, sure it's high and low just due to the weight on the lower side of the deck but over all it's great on hills with the very wide tires it has and hasn't been any problems to cut my hillsides. It does cut fast just because I run it full speed across the fields even on bumpy sections due to the full suspension front and rear. This gives a tremendous cut speed advantage compared to any other mower. Not many can do that at 10mph. Even the ZT2500 throws you around too much. This one has very heavy duty ZT3400 transmissions so it's good that way. (shop for transmissions first is the moto in ZTR's and i agree 100%). I have no complaints. Want to see the cut from it ? Here's a link to my front yard.
http://www.lhsc.net/microseven/fileimage.jpg
As for the ZT2500, I bought it about 5 years ago now. It has around 375hrs on it and has been ok. It has front suspension only and has 24hp with a 48" fabricated deck (both have them) with Gator blades installed. (Helps a lot with the cut on higher grass I've found) This one has the ZT2800 transmissions on it and i've changed the oil and filter in it twice now. Synthetic helps a lot on these transmissions to keep them smooth running. Both Transmissions have replaceable filters. A good thing you would want to get IMO. I can cut pretty fast with this mower but it's top speed is around 7mph so not as fast as the other one. And it does bounce around a lot in the field areas where it's just plain bumpy so slower is better but takes longer to do the job.
As for the Gravely, I don't have any experience with them other than my dealer carries both. He says the parts for the Gravely are very expensive. That was his only comment as I looked at them in the showroom last spring. REliability wise I would expect both to be similar as they mostly use parts from vendors like Kawasaki and Briggs and Stratton and Hydro Gear. I've only had one repair on the ZT2500 and that was a cracked bar that holds up the mower deck. I think from all the banging around in the fields with it broke it. Twice. The 2nd time I took it to a welder and he braced the crap out of it and it's been fine since. I think it was just a weak link since the mower deck is so heavy duty that banging over the moguls just broke a weaker asm. It's been fine since the weld two years ago now.
One thing I've found is that lowering the tire pressures helps a lot with traction and ride quality. By going from a rated 19lbs in the rear (bigger tires) to 10lbs it makes a big difference. Leaving the front ones at full pressure keeps them from getting flats easier I've found too. So they run at 25lbs. Just something that was interesting I found along the way.
Your call. I think both are good machines but if you have a bumpy, lumpy field like i do and want to cut the grass cutting time down, you can do that with full suspension at 10mph. It's pretty amazing and brings a smile to my face every time i rocket across them.
Steve
Steve
Thanks for the input, I was leaning toward the Simplicity, even though it is a few hundred more. I figured the suspension would be worth it. I'm going to take another look at them.
   / Simplicity Contender XT #4
Simplicity is owned, like Ferris Corp., by Briggs and Stratton. That suspension is patented by Ferris Corp.
You'll love the ride
I ended up buying a used Citation XT, couple years old, only 74 hours on it. When I was looking at new ones the dealer bounced up on down on the rear end of a contender it seemed pretty bouncy. This Citation seems pretty stiff even with the shocks on the lightest setting.
   / Simplicity Contender XT #6
Ride it across the lawn at full throttle. You'll see how the suspension and weight of the machine handles the bumps with ease. It's like no other having full suspension on it.
Steve loves ours.
   / Simplicity Contender XT #7
I bought a used 48" Simplicity Courier. It's their lowest end machine, but still has the independent suspension on it. I've only had it a year, but so far I really like. My yard is pretty rough but I don't find that I'm being beat up by the ride. I think that the mesh seat also helps.
If you're buying new and have the option of getting a Kawasaki engine instead of the B&S, go that route. I know that Ferris offers a Kawasaki option, but I'm not sure about Simplicity.
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
1827 (A51248)
1827 (A51248)
2007 Ford Ranger Pickup Truck (A51692)
2007 Ford Ranger...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2005 Ford E-450 Super Duty Ambulance (A51692)
2005 Ford E-450...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
