Simplicity Broadmoor electrical problem
   / Simplicity Broadmoor electrical problem #1
dannull
Damascus, MD
I have a 1995 Simplicity Broadmoor (model # 1692416) with a 14hp kholer engine that I bought as a project to fix up. It was not running when I bought it. I am having trouble with starting the mower. I checked the starter solenoid and found that I had power at the small terminal where the key switch hooks in so I figured I had a bad solenoid. When I got the new solenoid it also did not work. After testing the new solenoid if found that I still had power at the small terminal where the key switch hooks in but I also had power at the other small terminal. As I understand it this terminal is a ground terminal. Is this due to a bad safety switch or is something wired incorrectly in this mower? I thought a bad safety switch would kill power to the terminal hooked into the key switch. Also I have been unable to locate a wiring diagram for this mower, it is not included in the owners manual. Does anyone know where I can find one?
   / Simplicity Broadmoor electrical problem #2
Find where the other wire is going. If you have power on it means that it is not grounded properly.
2021 Fleco DX140 24in Tooth Bucket Excavator Attachment (A49461)
2021 Fleco DX140...
Brent 420 Grain Cart (A50514)
Brent 420 Grain...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A51222)
2018 FREIGHTLINER...
2012 GROVE TMS900E TRUCK CRANE (A50854)
2012 GROVE TMS900E...
2015 Ford F-150 4WD (A51039)
2015 Ford F-150...
2004 KENWORTH BUCKET TRUCK(INOPERABLE) (A50854)
2004 KENWORTH...
