Simplicity 7790 oil type
   / Simplicity 7790 oil type #1
nfzara
I recently purchased a 1984 Simplicity 7790 diesel garden tractor. It has a Lombardini 18HP engine. The owners manual calls for 40W oil of CD service class (DS series 3) . I have had no luck finding ANY straight 40W oil. The only straight weight oil I can find is 30W. Can Multi viscosity oils be used in these old engines. I emailed Lombardini and haven't gotten an answer. Can anyone shed some light on this for me. I sure don't want to use anything that would damage the engine. Thanks....Nick
   / Simplicity 7790 oil type #2
Well there's no oil out today that would "damage" your engine,that API classification of oil is long gone and a oil of today will work perfectly fine.
if it requires a 40w you can use any diesel HDEO 5w40 0r 15w40 depending on if the unit is used in the winter?
a multi grade oil listed above is still a 40w when at op temp so it'll work,todays oil's are leaps ahead of yesterdays oil.
   / Simplicity 7790 oil type #3
Check this thread for a discussion about a similar engine's oil needs. I'd guess RTS 5-40 or 10-30 would be the cat's whiskers for that unit... :thumbsup:
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
25in x 10in Kubota RTV-X1140 Tires (A52377)
25in x 10in Kubota...
2019 VOLVO L70H WHEEL LOADER (A52706)
2019 VOLVO L70H...
2007 MACK CV713 WINCH TRUCK (A53843)
2007 MACK CV713...
