Simplicity 700 Fuel Issue
   / Simplicity 700 Fuel Issue #1
monster318
PA
John Deere 318
Hello,
I have got a for the most part all original and good running Simplicity Model 700. One issue I have with it is that If the fuel tank is any less then 3/4 of the way full, it will not run, acts as if no fuel is getting to the carb. It used to be only if you went to start it after sitting over night that it wouldnt run with any less then 3/4 of a tank, now its getting to the point where it will die on you in the middle of mowing or just using it in general.
Here is a list of things I have done so far with no improvement:
1) New carb kit
2) New fuel line
3) Removed petcock from bottom of the tank and cleaned strainer, glass fuel bowl, and replaced o-ring gasket for fuel bowl.
4) Emptied tank completely dry and blew compressed air into to try and blow any debris out.
I am running out of options to try, If you take the fuel line off and hold it up even with where it inlets to the carb, fuel runs out of the line like it has no problem flowing or getting to the carb.
   / Simplicity 700 Fuel Issue #2
Not familiar with the simplicity 700 , something you can try is to pull a small gas tank off something else , push mower ,snowblower and see if your tractor will run off that held at various levels. If not and I suspect it won't , then you probably have something about your float or needle and seat that is binding or sticking.
Something else you can try is to put a small piece of vacuum hose in the filler neck with a rag held tightly around it and blow in it slightly to put a little pressure in the gas tank and see if that helps overcome any resistance in the carb.
Ray
   / Simplicity 700 Fuel Issue #3
I am not familiar with the this system.. but if you have a line that runs to the bottom of the gas tank,, then that line may have a hole in it about quarter of the way down.. when you get below that level then you start sucking air.. Lou
Unused Delta Crash...
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2020  FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52576)
2020 FREIGHTLINER...
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2013 Road King 30ft T/A Boat Trailer (A51694)
2013 Road King...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
