Simple computer question...I HOPE!
/ Simple computer question...I HOPE! #1
Henro
Super Member
Few miles north of Pgh, PA
Kubota B2910, BX2200, KX41-2V mini EX
I first came across this on a friend's computer. They are an elderly Japanese couple, and I was helping them set up a wireless network in their home, as they got a new computer in the living room, and had the old one upstairs...Got that up and running fine, except for that old computer.
Anywy, the stumbling block was that the operating system was Japanese windows 98, and instead of the \ symbol when the \ key was pressed, you got a "Y" like symbol, but actually it is the symbol for Japanese Yen (like the $ is here), and the system would stall when files were to be installed. Or so I think.
This morning I decided to get adventurous, and try to set up a couple of our computers for file sharing...and low and behold I find that on my computer, my wifes computer and her laptop, we also get a yen symbol rather than the \ when the \ key is pushed.
When I open a dos window and want to change directories by typing in cd\temp for example, I get cdYtemp, where the Y is actually the yen symbol. And the system tells me it cannot find the directory. However, if I type cd temp, the system changes to the temp directory without problem.
I don't think I set up my computer to display the Japanese language, but both of my wife's computers are set up to do so. All three are runnning windows XP. I did not yet check my older laptop that I have in my workshop, which is also running XP. I will do that later...
So my question is, what does one do to make the \ work like it should? The \ key does work normally in MS Word or Notepad. It also would not work properly in a windown where I needed to type in something like \\computer name\share or something like that...
Anyone have any thoughts? I don't really know who else to ask even... /forums/images/graemlins/crazy.gif I do know a lot of you guys are pretty sharp when it comes to computers /forums/images/graemlins/cool.gif
/ Simple computer question...I HOPE! #2
Not positive, but I'd try looking at Control Panel -> Regional and Language Options. Should be fairly obviouss once there what you'll need to do.
/ Simple computer question...I HOPE! #3
What is your default font? If it is Arial Unicode MS (ARIALUNI.TTF) then this MS Knowledge Base article may help you.
Arial Unicode MS font
If you are using another Unicode font I believe that you must locate the character that corresponds to the backslash (ansi 92).
You can also go to www.microsoft.com and do an advanced search for "japanese" in the knowledge base and you will get tons of Knowledge Base article hits. I have not looked thru all of them but you may find one that describes your problem.
/ Simple computer question...I HOPE! #4
Here is another interesting Knowledge Base article that deals with the keyboard setting used for Japanese. It may not exactly apply but may lead you to your problem.
Japanese 106/109 keyboard layout
MP and MR,
Thanks for the help. It is definately related to activating the Japanese language under windows...I disabled that on my computer last night, but did not do it a step at a time, so I don't know what feature actually causes the problem... /forums/images/graemlins/tongue.gif
So I will install (activate) the language feature a step at a time today and find out which feature I need to disable.
Thank for the help! /forums/images/graemlins/smile.gif
12 Ton Hydraulic Bottle Jack (A61567)
12 Ton Hydraulic...
2020 John Deere 333G High Flow Compact Track Loader Skid Steer (A61567)
2020 John Deere...
02GER CHICKET HOUSER 240F (A62131)
02GER CHICKET...
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
KUBOTA KX057-5 EXCAVATOR (A62129)
KUBOTA KX057-5...
UNUSED JCT HYD TREE/POST PULLER (A62131)
UNUSED JCT HYD...
