drag_slick
Bronze Member
This spring I upgraded from a Kubota BX1850 to a NH T2220 with supersteer. The loader has a quick attach and a 68" bucket. Huge difference, and made my snow removal much less of a battle.
What I noticed is that with the Kubota, if it couldn't lift something, it wouldn't even budge it off the ground. I was moving boulders with the boomer and there were boulders it would lift but then stop about 3' off the ground, seemed to hit the relief on the pump or something.
Rears are not loaded and I had a ~450lb tiller on the 3ph for ballast, tractor showed no signs of the back end lifting.
Just wondering if that's normal or should it be able to lift higher?
