I have a sight glass leaking on my 1998 L2900 Its the one for checking the transmission fluid level . I'll be changing all my fluids soon and would like to fix this problem , Is this a easy fix or do you have to go deep? Here is problem # 2 , I went to check the engine oil and when I pulled out the dip stick all that was there was the handel, the rest looked as if it had viberated off and into the pan. I have tried a magnet with no luck. I looked under the tractor and there is a shaft that runs under the pan , i'm going to try the magnet when I change the motor oil, there are 2 drain plugs on the pan so maby I'll get lucky and be able to fish it out , if not the pan will have to come down just wonder how much of job to drop the shaft?
Thanks in advance Larry
