Sifting through dirt
   / Sifting through dirt #1
kacole
Bronze Member
gaffney, sc
kubota mx5100
I cleared some land and got most of the brush burned off. Now I'm left with a bunch of piles of dirt with small pieces of wood in them. I have a grapple that I've used to shift through and get the large stuff out. What can I use to get the small stuff separated. I looked at on of the top soil screeners on YouTube but they look pretty expensive to build especially it you are going to put a motor on it to make it a shaker style. Dont know how effective it would be without it being a shaker. I also thought about one of the rock buckets for the fel although I dont know how well they work. Any suggestions would be great.
   / Sifting through dirt #2
Year's ago when my dad built his house on limited funds he made sifting boxes out of chicken wire and 2x4's on some wooden stands. He would use my grandfather's old David Bradley walk behind tiller to break up the clumps and then use my uncle's Case 646 which was a garden tractor with a loader to scoop and dump the material through the boxes. My grandfather also had a couple of Economy garden tractors with Cat0 lifts on them with some old-school pull implements to regrade the freshly sifted dirt. It took some time and family help but it did great and got all the stones and big debris out of the dirt.
   / Sifting through dirt #3
How about tilling or plowing etc harrowing the top soil, then using a landscape rake to gather the bigger stuff. Quit right there and let nature decompose the rest. Just a thought....maybe depends on how fine you want it.
Cheers,
Mike
   / Sifting through dirt #4
How big of a area are you talking about, that would have a lot to do with what I’d use?
   / Sifting through dirt #5
I think it depends on what you want to do with the area. Level it, run over it with a landscape rake as mentioned to pull the bigger pieces out, then let it go natural.
The main areas I have are piles I've pushed with a grapple. Lots of wood in them but way too much dirt to burn. I have probably 5 piles probably 6' deep 20' long and 8' high
Some of the piles was raked up with a landscape rake. Would like to make a yard out of the area so I would like to get rid of the piles
   / Sifting through dirt #8
Between the grapple, loader bucket, rake, maybe a back blade or other tools, you should be able to level the dirt and separate out the wood to better burn piles. When I burn brush, there isn't enough wood left to need to deal with. It's nearly all fine ash. I don't introduce a lot of dirt into the piles to begin with. Even stumps are left out in the rain to wash the dirt clods off before burning.
   / Sifting through dirt #9
Then you need to take the grapple, grab a load and shake the dirt out and make a new brush pile to burn.
I've done that (messy job) but most of the stuff I need to remove fall through the tines. my tines are spaced probably 8" apart
2008 VOLVO EC460CL (A52472)
2008 VOLVO EC460CL...
2008 Ford Ranger Pickup Truck (A51692)
2008 Ford Ranger...
HYDRAULIC SKID (A52472)
HYDRAULIC SKID...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
NEW Wolverine Skid Steer Drive and Augers (A53002)
NEW Wolverine Skid...
2023 Yamaha YXZ 100R SS (A51573)
2023 Yamaha YXZ...
