Side Sickle Bar Project
   / Side Sickle Bar Project #1
NCMau
NC
MF 202/Ford 8N
I am in the process of making a vertical sickle cutter attachment for my tractor. I am using a modified transmission and a 42" bar from a Gravely walk-behind tractor. This bar will be mounted in front of the loader arms and driven by a hydraulic motor.
Since I recently modified the tractor with a PTO pump to drive the loader, I will be using the on-board pump to drive the sickle. The hydraulic fluid will be supplied by the existing tractor selector valve, which I no longer use.
Just today I made a temporary connection from this valve to the sickle bar just to determine if it is compatible with I have.
The on-board pump is probably 4 or 5 GPM, the motor which I have on hand has a max of 15 GPM and a speed of 750 RPM. With this "with no load" setup seems to operate just fine. The 3pt lift is out of the operation and I can control the speed fro 0 to max with the position control.
I was planing to get a flow control valve but with this setup, I don't see why I would need it, unless it is for the reason that the flow control valve would have a built-in PRV. But then again, the on-board has a PRV and the sickle motor is the only device operated by the pump.
So, what do you guys think? Is this control valve really necessary?
I will post this project when it is completed.
2009 Mini Cooper Clubman Sedan (A50860)
2009 Mini Cooper...
John Deere 370 Flail Mower (A50860)
John Deere 370...
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
Chevrolet C8500 Flat Bed with a Moffet Kit (A51039)
Chevrolet C8500...
BUYERS PREMIUM & PAYMENT TERMS (A51219)
BUYERS PREMIUM &...
Ford Super Duty 8ft. Truck Bed (A48081)
Ford Super Duty...
