side or rear discharge
   / side or rear discharge #1
Anonymous Poster
Epic Contributor
I am looking at a new TC21D and can't decide what is better a 60" mmm side discharge or a 60" mmm rear discharge? Does anybody have any pro's or con's to either?
thanks in advance.
   / side or rear discharge #2
I've never used the rear discharge deck, but it sure looks appealing to me. I could cut both ways around my wifes numerous gardens and not spray grass clippings into them. A rear discharge deck may be in my future.
Jerry
   / side or rear discharge #3
I believe a rear discharge is less likely to leave windrows when cutting taller grass too.
   / side or rear discharge #4
I've got a 6' rear discharge MMM on my 33D and love it. Can mow close to things on either side of mower; no windrows. Only foreseeable problem is they're supposed to be a pain to remove and reattach to tractor.
   / side or rear discharge #5
My wife is into composting, and if I didn't have a side discharge mower, I'd be shot. I can push clipping in a little row for her. I do think the rear discharge would be better, no clogging, no winrows, and better mowing. That would have been my preference. Kent
   / side or rear discharge #6
As Kent says... The disadvantage of a rear discharge is that it can not be used to windrow the clippings... And the advantage of the rear discharge is that it will not windrow the clippings...
I really like my 60" Farm King 3ph rear discharge mower. Tough as nails, cuts very well, and cuts very fast. It seems to bounce around less than the TC21D does... which leads to a smoother cut. Much cheaper than the the NH MMM option. And much easier to remove.
   / side or rear discharge #7
Go with the rear discharge you won't regret it.
Happy Mowing!!
   / side or rear discharge #9
I have a rear discharge 3pt mower and definitely prefer it over a side discharge. There is only one disadvantage that I have come across, and that is a rare, if ever, situation. It’s mowing in reverse. I have an area where it’s faster and easier to back up into the grass rather than go forward and turn around each time. If the grass is very tall, it tends to be a problem because there’s no where for the clippings to go. But, the advantages mentioned far outweigh this.
   / side or rear discharge #10
I wanted a narrow (48 inch) rear mount mower so I can get between trees and between trees and fences. The only one I could locate was a Bush Hog side discharge. However, after using it for a bit I took off the side chute and bolted a 3/16 inch plate over the hole. It's the same principle as the "mulching kit" that is sold for some lawnmowers. My grass is too sparse to clog the mower so this has worked well. Because they can't escape as soon the clippings are cut up into smaller pieces and spread out evenly--no windrows. This won't work for anybody with a lush, thick lawn, but it works well for me.
1989 Ford FT900 T/A Cab and Chassis Truck (A51692)
1989 Ford FT900...
2005 Case 650K Series 2 LGP Crawler Tractor Dozer (A51691)
2005 Case 650K...
2017 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2017 John Deere...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
2019 Bobcat E32i Mini Excavator (A51691)
2019 Bobcat E32i...
