Side Mirrors
   / Side Mirrors #1
retired007
New Holland 3930 Kobota Zd21 Mule 4010 New HollandTZ25DA
I have a 4010 mule and wanted to put some side mirrors on it. Anybody found mirrors that they really like?
   / Side Mirrors #2
I have a 2018 Mule Pro DX EPS with Kawasaki side mirrors. I believe these mirrors have three settings one being folded back in the "out of the way" position.
They are constructed very well and I believe they look good too.
Premium Side Mirrors part #99994-0856 $123.96 from the dealer.
I am on the out of town and don't have a close up of the mirrors but have attached photos that I have on my computer. Hope it helps.
   / Side Mirrors #3
Lots of after-market choices for a lot less money.Just do a Google search.I purchased a set for about $50 for my 2016 Viking.
   / Side Mirrors #4
   / Side Mirrors #5
I have a set of Kolpin mirrors I got from Sportsman痴 Guide that I like. 2 side mirrors and 1 center. They have two different size inserts for the clamps to fit the roll cage pipe, a couple wraps of electrical tape nsures a tight grip. I have to remove the side mirrors when I install my soft cab though. 2016 4010 SE
   / Side Mirrors #6
Jackball, did you order your Mule outfitted or add the light bar, winches, and windshield? I have added an elec/hydraulic bed lift and 3500# winch on mine, thinking of doing a dual battery, heater, and hard windshield. 2016 4010 SE
   / Side Mirrors #7
I went a little nuts when I purchased the mule. I had the dealer install everything except the USB plug. I "installed" it myself in the 12 volt outlet on the dash. :)
I was quite surprised when I got the invoice....should have seen the sign behind the service counter "$100 Hour" Now I know better.
Anyway the list in long that I had the dealer install. I didn't get the hyd. bed lift because if I need to haul anything that needs to be dumped I will use the tractor and loader. Also I watched videos of them and they seem slow and tedious.
I have the Kawasaki heater too. It works good but I've seen after market that may be smaller and able to be tucked under the dash better. This one is okay though.
Also have the hard glass windshield and dual batteries.
The diesel is a little loud even though I've got the Kawasaki diesel noise reduction panel. When I get time in the future I will come up with something to reduce the decibels.
John Deere 700 Hydraulic Hay Rake - Durable Side Delivery Rake for Efficient Windrowing (A52128)
John Deere 700...
BUNDLE OF GALVANIZED CORRUGATED METAL SHEETS (A51244)
BUNDLE OF...
2015 Clarke Power Gen RC60D 47kW Towable Diesel Generator (A50322)
2015 Clarke Power...
UNUSED CFG Industrial H15R Mini Excavator (A47384)
UNUSED CFG...
90018 (A48082)
90018 (A48082)
(2) ROCK GUARDS FOR 2022 FORD BRONCO (A51244)
(2) ROCK GUARDS...
