Sickle Bar Sickle bar mower
   / Sickle bar mower #1
jhburke
Vermilion County, IL
2000 B7500HSD Kubota, 2 Case ingersol 448 tractors
I have a b7500hst and I would like to use a sickle bar mower on it. I have looked at some used ones but they are all at least 7'. Can my tractor handle that big of a sickle bar? Any help would be much appreciated. JIM
   / Sickle bar mower #2
First question, is it a 3 point attach or a trailer type, either can be PTO. If its 3 point, you may need considerable counter weight on the opposite side to offset the leverage of the sickle bar. My dad had about a 42" on a Sears garden tractor in the mid 60's, had over a hundred pounds of wheel weights on the left rear wheel to offset the bar on the right, this was mid-mount. unit, and you still had to watch out for tipping. I have used a JD 2355 with a 7 footer on a 3 point, and you could feel a lighter left side. Now if a trailer type, it should work with anysize tractor as long as it has the PTO power as it does not depend upon the tractor for stability, and if its a wheel drive unit PTO is not even a consideration.
Hope this helps. My advise, look for something in the 4 to 5 ' lenght for smaller tractor.
   / Sickle bar mower #3
I have a CASE T10 7' that I use with my B7300 (12.5 HP PTO) Hydro.
It is a trailer type. . . .
Never had a problem even in high weeds or full grown sweet corn.
Must keep blade sections sharp and rock guards in good shape.
   / Sickle bar mower #4
Sickle bar mowing..now that brings back memories from the past for me /w3tcompact/icons/eyes.gif and lot of other TBNer's.
I do hope the newer sickle bar blades are easier to sharpen other than a old hand file,and they don't break down as much.
Just wondering why you are considering a sickle bar,for you have flat w/some hilly areas and a rear mower easier to handle.
   / Sickle bar mower #5
I've got an Enorossi 7' sickle bar. I'm not sure how much hp your tractor has, but the specs for the Enorrosi say it requires from 20 to 30hp. The unit weighs 530 lbs. They also sell a unit with a 6' bar that weighs 496 lbs. Same hp spec.
Since I got the Enorossi my old NH 451 has been sitting in the weeds. It weighs less than the NH. Has a hydraulic cylinder to raise or lower. You can cut at any angle from 90 degrees up from horiz. to 75 degrees below horiz. The best feature is that it has a scissor action so it seldom clogs unlike the NH which even with one of the double tooths on the end still clogs.
   / Sickle bar mower
I want it to cut ditch banks and around a pond. I want to use a 3 point model. I was concerned about it making the tractor tippy. But I don't like getting real close to the pond edge. I have already had the front wheels slide in twice. Don't like that at all. JIM
   / Sickle bar mower #7
i gave up on the sickle idea and went with the line trimmer.
this was due to two things, 1 - lots of rock [riprap] that would ding the sickle, and 2 - the banks were not 4100-friendly [too steep and too narrow in case the sickle caught on something].
i would really like to here about any sickle mowing pond/lake/creek bank experiences!
   / Sickle bar mower #8
jh, this is your lucky day!
I just happen to have a JD4100 hydro, for which I acquired a kuhn 6' Sickle Bar mower, which I have decided to let go at a very reasonable price {grin}
Please pardon that unabashed advertising
I think our tractors are pretty similar - the unit I have works pretty well. I originally bought it to mow a bank, including cutting down 1" saplings. It worked okay, but after using it I decided there were easier ways to do what I wanted to do - Sickle-Bar mowers really work best in hayfields. It's a 3-point hitch model, has a hydro. lift, can be offset to compensate for the blade weight, and it does have what's called a "pittman" arm, which is what drives the blades. (That's not considered the best way to drive the blades - newer models use a different technique to reciprocate the blades.)
To specifically answer your question - it depends on what you're trying to do with the SB you're contemplating. Running slower, cutting grass - probably would work.
Let me know if you want anymore info
   / Sickle bar mower #10
Darren:
From way back I recall a sickle bar mower only required about two horse power.
Egon
2017 Ram 5500 4x4 Utility Truck, VIN # 3C7WRNEL7HG551780 (A48836)
2017 Ram 5500 4x4...
2015 MACK GU713 (INOPERABLE) (A50854)
2015 MACK GU713...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2000 WINNEBAGO FORD F550 RV (A50854)
2000 WINNEBAGO...
2017 Freightliner Cascadia 125 Single Axle Sleeper Cab Truck Tractor (A50323)
2017 Freightliner...
Hyster H155XL Forklift (A48837)
Hyster H155XL...
