Sickle Attachment
   / Sickle Attachment #1
NCMau
NC
MF 202/Ford 8N
I am in the process of making a vertical sickle cutter attachment for my tractor by using a modified transmission and a 42" bar from a Gravely walk-behind tractor. This bar will be mounted in front of the loader arms and driven by a hydraulic motor.
Since I recently modified the tractor with a PTO pump to drive the loader, I will be using the on-board pump to drive the sickle bar. The hydraulic fluid will be supplied by the existing tractor selector valve, which I no longer use.
Just made a temporary connection from this valve to the sickle bar to determine if it is compatible with what I have.
The on-board pump is probably 4 or 5 GPM, the motor which I have on hand has a max of 15 GPM and a speed of 750 RPM. With this "no load" setup seems to operate just fine. The 3pt lift is out of the operation and I can control the speed fro 0 to max with the position control.
I was planing to get a flow control valve, but with this setup, I don't see why I would need it, unless it is for the reason that the flow control valve would have a built-in PRV. But then again, the on-board pump has a PRV and the sickle motor is the only device operated by the pump.
My Question: Is this flow control valve really necessary?
   / Sickle Attachment #2
If the hyd motor uses 15 GPM for a 750 rpm speed, based on cu in displacement, and your tractor only puts out 5 GPM, then the hyd mtor wil run at a speed equal to the 5 GPM which will be about 1/3 , or 250 rpm.
If the sickle bar cuts OK, then all is well, and the tractor lever needs to be fully open or locked open with a bungee.
If the pressure rating on the hyd motor is about 3000, then a tractor relief setting of 2950 will relieve the pressure on the hyd motor if it develops that pressure.
   / Sickle Attachment
From what I can determine so far, the speed is perfect, actually a little too fast without restricting the fluid. Once the load is applied, I should be able to have full control. I just hope the equivalent torque will be sufficient.
Waiting for some fittings from SC.
2016 Chevrolet Impala LT Limited Sedan (A48082)
2016 Chevrolet...
2016 Poulan Pro PP19A42 42in. Riding Mower (A49346)
2016 Poulan Pro...
New/Unused 20ft Farm Iron Gate (A48837)
New/Unused 20ft...
Miller Millermatic 130 XP Welding Machine (A50860)
Miller Millermatic...
Huffy NEL LUSSO Bicycle (A50860)
Huffy NEL LUSSO...
Bundle of 40 Gauge Pipe (A50860)
Bundle of 40 Gauge...
