Traction Shuttle
   / Shuttle #1
reeltime
East Freetown ma
2014 mahindra 3016 shuttle loader and backhoe with thumb
New to shuttle ? To you shuttle owners do you use hand or foot throttle and if you use hand throttle do you throttle down when shifting from foward to reverse.i know to idle it to shift gears
   / Shuttle #2
If I'm doing loader work, forward/reversing or mowing around trees, Etc where I need to speed up/slow down I use the foot throttle.
If I'm mowing open areas where I can run continuous speeds I use the hand throttle.
I think I use my foot throttle 80% of the time I'm on the tractor.
   / Shuttle
Thank you that what I do runs hand work foot so I am good really liking shuttle owned 3 hydros in the past shuttle more wheel power thanks
   / Shuttle #4
I usually give it enough hand throttle to make things work smooth, then give it a little foot throttle when needed to raise loader or go into a load.
   / Shuttle #5
about only time hand throttle ever used is for backhoe work. to many turns and and down slopes, getting around trees and like when mowing. to use hand throttle. even on my long straight away dirt road, i simply do not have long enough road to put hand throttle on.
for the old ford 555C TLB, i think manual states to lower RPM's between 1-4 gear shifting. the gear shifter, shuttle shift lever by steering wheel have clutch buttons on them. and the FEL stick also has a clutch button but is noted not to be used for shifting.
all in all, just thinking about how a hydraulic transmission works and gears in general... i would say let off the throttle. when shifting. or you are more likely to cause pressure relief valves to go off, and cause extra heat build up, and in that more wear and tear on the unit.
i generally let off foot throttle regardless when going from backwards to forwards or vice vs., so i do not rock and get the machine to start bouncing. (i like a smooth ride, nut a bunking bronco).
while a the hydraulic system might handle going quickly from forward to reverse and vice vs. (and i tend to use it heavily with loader work and turning around). i do slow things down. (not a young kid that is a ram rod, with foot on pedal and through the floor board)
   / Shuttle #6
My tractor is my first and I use the hand throttle 80% of the time.... when it is running :) (my own inside joke at the moment...)
I do not throttle down when shifting typically unless I have loaded the bucket up or are doing "delicate" work.
Wolverine Quick Attach Tree Spade (A50514)
Wolverine Quick...
2020 Massey Ferguson 1840 Small Square Baler - High-Performance Hay Baler (A52128)
2020 Massey...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Mini Forks (A50322)
Mini Forks (A50322)
500 gal Fuel Barrel with Pump (A50515)
500 gal Fuel...
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
