Shuttle shift?
   / Shuttle shift? #1
wags4x4
I just picked up a Millennium T550. The manual says shuttle shift transmission but the details are unclear. Can you really shift from forward to neutral to reverse without the clutch on this thing? I have used shuttle shift on larger equipment and was wondering if it should work the same.
   / Shuttle shift? #2
The type you have is a scyncro shuttle and you need to clutch it every time. TYM has only offered a power shuttle the past couple years on the T603, T723, T903 & T1003. With the power shuttle you can shift with out clutching. For the rest you must clutch. The scyncro shuttle is a good basic time tested design that has held up well.
   / Shuttle shift?
I tried to shuttle it without the clutch last night and I could get it to go but it was hard. I agree, the clutch is needed.
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
(APPROX 250) UNUSED LANDHERO 30" TRAFFIC CONES (A51248)
(APPROX 250)...
2023 WESSEX RMX500 LOT IDENTIFIER 44 (A53084)
2023 WESSEX RMX500...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
